American-DJ - Galaxian 3D Lasers
Postby gilsontech » 08 May 2010, 06:26
Can I get the profile for the Galaxian 3D laser:
http://americandj.com/ProductDetails.as ... umber=1868
http://americandj.com/pdffiles/galaxian_3d.pdf
Thank you very much!!
-Josh
Working on the next BIG thing
gilsontech
Re: American DJ Galaxian 3D Lasers
Postby support » 08 May 2010, 18:21
Done.
Re: American-DJ - Galaxian 3D Lasers
Postby gilsontech » 19 May 2010, 03:20
Thanks! Does this work in version 5 also?
gilsontech
Postby support » 20 May 2010, 00:25
No, it does not.
You must add a first line "Name = ..." in the TXT file, and it will work in V5.
We suggest you to open an existing personality file from V5 and you will certainely understand.
Postby gilsontech » 23 May 2010, 07:52
Thanks, but when i make the ofrmat look the other v5 files. See example below. The title just says " = AMERICAN-DJ_GALAXIAN3D" and no channel values are found. What'd I do wrong?
Name = AMERICAN-DJ_GALAXIAN3D
ViewType = VIEW_TYPE_NOTHING
ViewPower = VIEW_POWER_LED30W
ViewAnglePan = 120
ViewAngleTilt = 120
ViewAngleBeam = 16
ViewReversePan = FALSE
ViewReverseTilt = FALSE
ViewReverseDimmer = FALSE
ViewReverseIris = FALSE
ViewColor = 16777215
Channel = red_laser
closed,0,0 strobe,16,239 audio,243,243 open,255,255
Channel = green_laser
Channel = rotation1
stop,0,127 left_rotate,128,189 stop,191,191 right_rotate,194,255
Channel = rotation2
Channel = macro
closed,0,0 macro_1,15,15 macro_2,30,30 macro_3,47,47 macro_4,62,62 macro_5,80,80 macro_6,95,95 macro_7,110,110 macro_8,128,128 macro_9,142,142 macro_10,160,160 macro_11,175,175 macro_12,190,190 macro_13,207,207 macro_14,222,222 macro_15,240,240 audio,255,255
-Josh
gilsontech
Postby support » 24 May 2010, 08:51
Here is the profile compatible with V5:
Postby gilsontech » 25 May 2010, 21:05
thank you
gilsontech
Users browsing this forum: No registered users and 74 guests
