will not work on android 2.3.6
Postby troubadour » 02 November 2012, 19:35
Hello there,
until about 2 weeks ago, live mobile worked fine on my samsung ace with android 2.3.6.
I updated live mobile and after this update i cannot talk to live anymore.
I get i socket error.
Reinstalling does not fix the problem, because this version of live mobile is the problem, and that is the version you can download and install.
There are many more that have this problem, look on the download site !!
There are more people using the old software or an ipad, and then everything works fine.
So plesase fix this, or make it an option to install the old version.
With kind regards, Jos ter Horst.
troubadour
Re: will not work on android 2.3.6
Postby support » 03 November 2012, 08:34
Yes, there is a problem with the IOS app.
The Android app is a different app.
Postby troubadour » 06 November 2012, 14:02
Can you please put the old version back again to download, because this one worked fine, and i bought, installed the software to be able to use it, and now i cannot use as i planned.
troubadour
Postby troubadour » 06 November 2012, 14:10
Hello there, reading in all the groups about version 2.0, this one doesn,t work, so stop trying, put 1.1 ready to download, so that we can all benefit from the good things, instead of getting a headache from the new version.
And put version 2.0 back up when it is working as it should.
With kind regards, Jos.
troubadour
Postby support » 06 November 2012, 17:39
Both are available here: viewtopic.php?f=3&t=114
Postby troubadour » 06 November 2012, 21:24
Hmmmmm and where can i find live_mobile version 1.1 ?? because searching everything in the link you put on as an answer, there is no version 1.1 for android or the version for ios
We only have problems with live mobile and want that back the way it was, WORKING.
It it ain't broke, don't fix it !!
troubadour
Postby support » 07 November 2012, 08:07
There is only the apps for Android (1.1 and 2.0).
Apple® does not allow to self install apps.
Postby troubadour » 08 November 2012, 19:26
But where can i find version 1.1 for android ??
I cannot find it anywhere.
And why not go back to the working (old) version ?
troubadour
Postby support » 09 November 2012, 08:14
The Android app V1.1 is available here viewtopic.php?f=3&t=114, in "The smartphone app" > "direct download"
Postby troubadour » 23 December 2012, 21:12
and when is the new version coming ??
We still have problems with version 2.0, it doesn't work !!!
And sometimes the android and the apple versions are updated, and then it doesn's work anymore, so fix this, make a version 3.0 or remove/take back the crappy version 2.0 !!
Jos.
troubadour
Return to Android
Users browsing this forum: No registered users and 27 guests
