OS2L not working on VDJ2020 [fixed]
live control with Virtual DJ
Re: OS2L not working on VDJ2020
Postby Pauluzzz » 11 May 2020, 12:26
As an additional comment, ensure your firewall has port 5353 enabled, as the Bonjour networking protocol sends and receives network packets on UDP port 5353. If my Avast virus scanner for example, determines the WiFi network is "Public" it will block this port by default and Bonjour won't work, hence the signal between Virtual DJ and Sweetlight do not arrive. Make sure the port is enabled.
Pauluzzz
Postby support » 11 May 2020, 13:42
Thank you for this info.
Postby Niffo » 14 September 2022, 17:54
FYI, we tested VDJ OS2L without Apple/Bonjour and it works here with the last version of VDJ (8.5-64 b7131) :
- In VDJ, ensure the parameter "os2l" is set to "yes" and the parameter "os2lDirectIp" is set to "127.0.0.1:7350" (if working on the same machine).
- Sadly, for the beat to be sent by VDJ, you have to trigger a live button with a VDJ pad first.
- You can ignore the error message about "Bonjour" at the start of our software. A coming fix file will allow to not try to initialize Apple/Bonjour.
Postby support » 16 September 2022, 15:49
Previous
Return to Virtual DJ
Users browsing this forum: No registered users and 19 guests
