3D viewer LED bar always strobing
Postby ColterCreation » 14 September 2022, 03:35
I've checked the stickied 10+ year old post located https://thelightingcontroller.com/viewt ... f=13&t=372, but changing my ADJ MegaBarLED (9ch) dimmer channel to "shutter" and adding a "strobe" level doesn't resolve this issue as the short post says to do. Has anyone else been able to solve this issue where you can't stop the flicker/strobing in 3d viewer? Thank you for your input.
-Colter
ColterCreation
Re: 3D viewer LED bar always strobing
Postby support » 14 September 2022, 07:15
Please post the profile (.txt file) of this DMX fixture.
We will check it.
Postby ColterCreation » 14 September 2022, 23:09
support wrote:Please post the profile (.txt file) of this DMX fixture.
We will check it.
Thank you. Here it is attached.
MegaBar.txt
ADJ MegaBar 9Ch
(479 Bytes) Downloaded 238 times
Please let me know if you can explain why this is occurring so I can better be equipped to navigate future issues like this. Thank you!!!
ColterCreation
Postby support » 15 September 2022, 07:24
Please try the attached one.
We made the changes explained in your first post (https://thelightingcontroller.com/viewt ... f=13&t=372).
BUT
the 3 levels (closed, strobe, open) DMX values have to be updated.
We were not able to find the correct DMX values in this manual: http://adjmedia.s3-website-eu-west-1.am ... ar_LED.pdf
because this manual does not show any 9 channels mode.
MegaBar.txt
(513 Bytes) Downloaded 227 times
Return to 3DView
