Monterey - Show express
Postby Ray825 » 20 July 2022, 02:42
Trying to run show express with my Mac using Monterey. It was working fine then stop. I removed the program and downloaded again. Now when I try to bring a fixture in it crashes. Anyone have any advice with this issue ?
Ray825
Re: Monterey - Show express
Postby support » 20 July 2022, 14:24
There may be a corrupted file in your lightshow (?)
Please post a ZIP to download your lightshow (https://thelightingcontroller.com/viewt ... ?f=3&t=168). We will check it.
Postby Ray825 » 20 July 2022, 20:15
It crashes when I try to load a fixture so I can't get as far as creating a light show. I pasted below error message.
Translated Report (Full Report Below)
Process: TheLightingController [1585]
Path: /Volumes/*/TheLightingController.app/Contents/MacOS/TheLightingController
Identifier: TheLightingController
Version: 0.1
Code Type: X86-64 (Native)
Parent Process: launchd [1]
User ID: 501
Date/Time: 2022-07-20 15:57:49.5120 -0400
OS Version: macOS 12.4 (21F79)
Report Version: 12
Bridge OS Version: 6.5 (19P5071)
Anonymous UUID: CB6679A9-F4BD-8DA0-AD6B-16A571655F5B
Sleep/Wake UUID: 49ACCFE5-1901-4A70-967E-48D19C5E13F9
Time Awake Since Boot: 26000 seconds
Time Since Wake: 11458 seconds
System Integrity Protection: enabled
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000028
Exception Codes: 0x0000000000000001, 0x0000000000000028
Exception Note: EXC_CORPSE_NOTIFY
Termination Reason: Namespace SIGNAL, Code 11 Segmentation fault: 11
Terminating Process: exc handler [1585]
VM Region Info: 0x28 is not in any region. Bytes before following region: 140737487101912
REGION TYPE START - END [ VSIZE] PRT/MAX SHRMOD REGION DETAIL
UNUSED SPACE AT START
VM_ALLOCATE 7fffffece000-7fffffecf000 [ 4K] r-x/r-x SM=ALI
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 TheLightingController 0x1000e0dc1 0x100000000 + 921025
Thread 1:
0 libsystem_pthread.dylib 0x7ff8190b3f48 start_wqthread + 0
Thread 2:
0 libsystem_kernel.dylib 0x7ff81907e2be __semwait_signal + 10
1 libsystem_c.dylib 0x7ff818f92863 nanosleep + 196
2 TheLightingController 0x1001a0ab7 0x100000000 + 1706679
3 TheLightingController 0x1000ae494 0x100000000 + 713876
Thread 3:: com.apple.NSEventThread
0 libsystem_kernel.dylib 0x7ff81907b97a mach_msg_trap + 10
1 libsystem_kernel.dylib 0x7ff81907bce8 mach_msg + 56
2 CoreFoundation 0x7ff81917f38d __CFRunLoopServiceMachPort + 319
3 CoreFoundation 0x7ff81917da18 __CFRunLoopRun + 1276
4 CoreFoundation 0x7ff81917ce5c CFRunLoopRunSpecific + 562
5 AppKit 0x7ff81bd29c1e _NSEventThread + 132
6 libsystem_pthread.dylib 0x7ff8190b84e1 _pthread_start + 125
7 libsystem_pthread.dylib 0x7ff8190b3f6b thread_start + 15
Thread 4:
3 TheLightingController 0x10013074f 0x100000000 + 1247055
Thread 5:
Thread 6:
Thread 7:
Thread 8:
Thread 9:
Thread 10:
Thread 11:
Thread 0 crashed with X86 Thread State (64-bit):
rax: 0x0000000000000000 rbx: 0x0000000100001b60 rcx: 0x0000000000000200 rdx: 0x0000000000000000
rdi: 0x0000000000000000 rsi: 0x0000000000000000 rbp: 0x0000000000000000 rsp: 0x00007ff7bfeff7f0
r8: 0x0000600002c0bae0 r9: 0x0000000000000000 r10: 0x00000001002d2f60 r11: 0x00007ff81bbf2877
r12: 0x00007ff85a8384e0 r13: 0x00000001003b7680 r14: 0x0000000000000000 r15: 0x0000000000000001
rip: 0x00000001000e0dc1 rfl: 0x0000000000010202 cr2: 0x0000000000000028
Logical CPU: 6
Error Code: 0x00000004 (no mapping for user data read)
Trap Number: 14
Thread 0 instruction stream:
48 8d 2d a0 1b 2a 00 48-0f b6 45 23 49 39 c7 0f H.-..*.H..E#I9..
85 cf 1f 00 00 48 8b 2d-c7 25 2a 00 4c 0f bf 7d .....H.-.%*.L..}
30 4c 0f bf 75 30 49 ff-ce 4c 89 f0 48 89 c0 50 0L..u0I..L..H..P
5f e8 67 8d 07 00 49 89-c6 49 ff ce 49 c1 e6 09 _.g...I..I..I...
4d 29 f7 4c 89 bc 24 b0-00 00 00 4c 8b bc 24 b0 M).L..$....L..$.
00 00 00 48 8b 2d 89 25-2a 00 48 8b 6d 28 55 58 ...H.-.%*.H.m(UX
[ff]75 28 5f e8 66 a9 0d-00 49 01 c7 4c 89 bc 24 .u(_.f...I..L..$ <==
b8 00 00 00 4c 8b bc 24-b0 00 00 00 49 ff cf 4c ....L..$....I..L
89 f8 48 c7 c1 20 00 00-00 48 99 48 f7 f9 49 89 ..H.. ...H.H..I.
c7 4c 89 bc 24 c0 00 00-00 4c 8b bc 24 b8 00 00 .L..$....L..$...
00 49 ff cf 4c 89 f8 48-c7 c1 20 00 00 00 48 99 .I..L..H.. ...H.
48 f7 f9 49 89 c7 4c 89-bc 24 c8 00 00 00 4c 8b H..I..L..$....L.
Binary Images:
0x100000000 - 0x1002bbfff TheLightingController (*) <b01c0629-6aa2-3c78-a210-8e3b6420fcab> /Volumes/*/TheLightingController.app/Contents/MacOS/TheLightingController
0x7ff8190b2000 - 0x7ff8190bdfff libsystem_pthread.dylib (*) <bc574849-1aae-31e7-b350-916dda999d97> /usr/lib/system/libsystem_pthread.dylib
0x7ff81907a000 - 0x7ff8190b1fff libsystem_kernel.dylib (*) <61711d11-e776-3bc3-b9a2-6f9f37cb8499> /usr/lib/system/libsystem_kernel.dylib
0x7ff818f82000 - 0x7ff81900afff libsystem_c.dylib (*) <d9ba0660-744d-3f84-9f80-afb51d450512> /usr/lib/system/libsystem_c.dylib
0x7ff8190ff000 - 0x7ff819601fff com.apple.CoreFoundation (6.9) <f8e45ef9-9fd2-3331-bb1b-703d5dacdaf1> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7ff81bb7d000 - 0x7ff81ca0bfff com.apple.AppKit (6.9) <832ad371-d3b8-3061-b4e2-1c4e0cffce0b> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x0 - 0xffffffffffffffff ??? (*) <00000000-0000-0000-0000-000000000000> ???
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=961.0M resident=0K(0%) swapped_out_or_unallocated=961.0M(100%)
Writable regions: Total=1.8G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=1.8G(100%)
VIRTUAL REGION
REGION TYPE SIZE COUNT (non-coalesced)
Accelerate framework 640K 5
Activity Tracing 256K 1
CG backing stores 2880K 4
CG image 32.5M 124
ColorSync 224K 26
CoreAnimation 111.1M 130
CoreGraphics 12K 2
CoreUI image data 2972K 24
Foundation 16K 1
Kernel Alloc Once 8K 1
MALLOC 318.2M 66
MALLOC guard page 48K 10
MALLOC_MEDIUM (reserved) 944.0M 8 reserved VM address space (unallocated)
MALLOC_NANO (reserved) 384.0M 1 reserved VM address space (unallocated)
ObjC additional data 15K 1
STACK GUARD 56.0M 12
Stack 15.1M 12
VM_ALLOCATE 18.7M 100
__CTF 756 1
__DATA 21.4M 369
__DATA_CONST 19.1M 223
__DATA_DIRTY 913K 134
__FONT_DATA 4K 1
__LINKEDIT 648.2M 10
__TEXT 312.8M 387
__UNICODE 592K 1
dyld private memory 1024K 1
mapped file 144.2M 21
shared memory 784K 17
TOTAL 3.0G 1693
TOTAL, minus reserved VM space 1.7G 1693
Full Report
{"app_name":"TheLightingController","timestamp":"2022-07-20 15:57:51.00 -0400","app_version":"","slice_uuid":"b01c0629-6aa2-3c78-a210-8e3b6420fcab","build_version":"0.1","platform":1,"share_with_app_devs":0,"is_first_party":1,"bug_type":"309","os_version":"macOS 12.4 (21F79)","incident_id":"73F208ED-F455-43F9-B132-D39A2458B92E","name":"TheLightingController"}
"uptime" : 26000,
"procLaunch" : "2022-07-20 15:57:20.0582 -0400",
"procRole" : "Foreground",
"version" : 2,
"userID" : 501,
"deployVersion" : 210,
"modelCode" : "Macmini8,1",
"procStartAbsTime" : 26749847751187,
"coalitionID" : 1832,
"osVersion" : {
"train" : "macOS 12.4",
"build" : "21F79",
"releaseType" : "User"
"captureTime" : "2022-07-20 15:57:49.5120 -0400",
"incident" : "73F208ED-F455-43F9-B132-D39A2458B92E",
"bug_type" : "309",
"pid" : 1585,
"procExitAbsTime" : 26779301836977,
"cpuType" : "X86-64",
"procName" : "TheLightingController",
"procPath" : "\/Volumes\/*\/TheLightingController.app\/Contents\/MacOS\/TheLightingController",
"bundleInfo" : {"CFBundleVersion":"0.1"},
"parentProc" : "launchd",
"parentPid" : 1,
"crashReporterKey" : "CB6679A9-F4BD-8DA0-AD6B-16A571655F5B",
"wakeTime" : 11458,
"bridgeVersion" : {"build":"19P5071","train":"6.5"},
"sleepWakeUUID" : "49ACCFE5-1901-4A70-967E-48D19C5E13F9",
"sip" : "enabled",
"vmRegionInfo" : "0x28 is not in any region. Bytes before following region: 140737487101912\n REGION TYPE START - END [ VSIZE] PRT\/MAX SHRMOD REGION DETAIL\n UNUSED SPACE AT START\n---> \n VM_ALLOCATE 7fffffece000-7fffffecf000 [ 4K] r-x\/r-x SM=ALI ",
"isCorpse" : 1,
"exception" : {"codes":"0x0000000000000001, 0x0000000000000028","rawCodes":[1,40],"type":"EXC_BAD_ACCESS","signal":"SIGSEGV","subtype":"KERN_INVALID_ADDRESS at 0x0000000000000028"},
"termination" : {"flags":0,"code":11,"namespace":"SIGNAL","indicator":"Segmentation fault: 11","byProc":"exc handler","byPid":1585},
"vmregioninfo" : "0x28 is not in any region. Bytes before following region: 140737487101912\n REGION TYPE START - END [ VSIZE] PRT\/MAX SHRMOD REGION DETAIL\n UNUSED SPACE AT START\n---> \n VM_ALLOCATE 7fffffece000-7fffffecf000 [ 4K] r-x\/r-x SM=ALI ",
"extMods" : {"caller":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"system":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"targeted":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"warnings":0},
"faultingThread" : 0,
"threads" : [{"triggered":true,"id":143785,"instructionState":{"instructionStream":{"bytes":[72,141,45,160,27,42,0,72,15,182,69,35,73,57,199,15,133,207,31,0,0,72,139,45,199,37,42,0,76,15,191,125,48,76,15,191,117,48,73,255,206,76,137,240,72,137,192,80,95,232,103,141,7,0,73,137,198,73,255,206,73,193,230,9,77,41,247,76,137,188,36,176,0,0,0,76,139,188,36,176,0,0,0,72,139,45,137,37,42,0,72,139,109,40,85,88,255,117,40,95,232,102,169,13,0,73,1,199,76,137,188,36,184,0,0,0,76,139,188,36,176,0,0,0,73,255,207,76,137,248,72,199,193,32,0,0,0,72,153,72,247,249,73,137,199,76,137,188,36,192,0,0,0,76,139,188,36,184,0,0,0,73,255,207,76,137,248,72,199,193,32,0,0,0,72,153,72,247,249,73,137,199,76,137,188,36,200,0,0,0,76,139],"offset":96}},"threadState":{"r13":{"value":4298864256},"rax":{"value":0},"rflags":{"value":66050},"cpu":{"value":6},"r14":{"value":0},"rsi":{"value":0},"r8":{"value":105553162451680},"cr2":{"value":40},"rdx":{"value":0},"r10":{"value":4297928544},"r9":{"value":0},"r15":{"value":1},"rbx":{"value":4294974304},"trap":{"value":14,"description":"(no mapping for user data read)"},"err":{"value":4},"r11":{"value":140703594129527,"symbolLocation":0,"symbol":"-[NSView frame]"},"rip":{"value":4295888321,"matchesCrashFrame":1},"rbp":{"value":0},"rsp":{"value":140702053824496},"r12":{"value":140704647185632,"symbolLocation":0,"symbol":"dyld4::gDyld"},"rcx":{"value":512},"flavor":"x86_THREAD_STATE","rdi":{"value":0}},"queue":"com.apple.main-thread","frames":[{"imageOffset":921025,"imageIndex":0}]},{"id":143819,"frames":[{"imageOffset":8008,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":1}]},{"id":143828,"frames":[{"imageOffset":17086,"symbol":"__semwait_signal","symbolLocation":10,"imageIndex":2},{"imageOffset":67683,"symbol":"nanosleep","symbolLocation":196,"imageIndex":3},{"imageOffset":1706679,"imageIndex":0},{"imageOffset":713876,"imageIndex":0}]},{"id":143834,"name":"com.apple.NSEventThread","frames":[{"imageOffset":6522,"symbol":"mach_msg_trap","symbolLocation":10,"imageIndex":2},{"imageOffset":7400,"symbol":"mach_msg","symbolLocation":56,"imageIndex":2},{"imageOffset":525197,"symbol":"__CFRunLoopServiceMachPort","symbolLocation":319,"imageIndex":4},{"imageOffset":518680,"symbol":"__CFRunLoopRun","symbolLocation":1276,"imageIndex":4},{"imageOffset":515676,"symbol":"CFRunLoopRunSpecific","symbolLocation":562,"imageIndex":4},{"imageOffset":1756190,"symbol":"_NSEventThread","symbolLocation":132,"imageIndex":5},{"imageOffset":25825,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8043,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":143849,"frames":[{"imageOffset":17086,"symbol":"__semwait_signal","symbolLocation":10,"imageIndex":2},{"imageOffset":67683,"symbol":"nanosleep","symbolLocation":196,"imageIndex":3},{"imageOffset":1706679,"imageIndex":0},{"imageOffset":1247055,"imageIndex":0}]},{"id":143851,"frames":[{"imageOffset":17086,"symbol":"__semwait_signal","symbolLocation":10,"imageIndex":2},{"imageOffset":67683,"symbol":"nanosleep","symbolLocation":196,"imageIndex":3},{"imageOffset":1706679,"imageIndex":0},{"imageOffset":1247055,"imageIndex":0}]},{"id":143853,"frames":[{"imageOffset":8008,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":1}]},{"id":143855,"frames":[{"imageOffset":8008,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":1}]},{"id":144101,"frames":[{"imageOffset":8008,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":1}]},{"id":144102,"frames":[{"imageOffset":8008,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":1}]},{"id":144103,"frames":[{"imageOffset":8008,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":1}]},{"id":144104,"frames":[{"imageOffset":8008,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":1}]}],
"usedImages" : [
"source" : "P",
"arch" : "x86_64",
"base" : 4294967296,
"size" : 2867200,
"uuid" : "b01c0629-6aa2-3c78-a210-8e3b6420fcab",
"path" : "\/Volumes\/*\/TheLightingController.app\/Contents\/MacOS\/TheLightingController",
"name" : "TheLightingController",
"CFBundleVersion" : "0.1"
"source" : "P",
"arch" : "x86_64",
"base" : 140703548776448,
"size" : 49152,
"uuid" : "bc574849-1aae-31e7-b350-916dda999d97",
"path" : "\/usr\/lib\/system\/libsystem_pthread.dylib",
"name" : "libsystem_pthread.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 140703548547072,
"size" : 229376,
"uuid" : "61711d11-e776-3bc3-b9a2-6f9f37cb8499",
"path" : "\/usr\/lib\/system\/libsystem_kernel.dylib",
"name" : "libsystem_kernel.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 140703547531264,
"size" : 561152,
"uuid" : "d9ba0660-744d-3f84-9f80-afb51d450512",
"path" : "\/usr\/lib\/system\/libsystem_c.dylib",
"name" : "libsystem_c.dylib"
"source" : "P",
"arch" : "x86_64h",
"base" : 140703549091840,
"CFBundleShortVersionString" : "6.9",
"CFBundleIdentifier" : "com.apple.CoreFoundation",
"size" : 5255168,
"uuid" : "f8e45ef9-9fd2-3331-bb1b-703d5dacdaf1",
"path" : "\/System\/Library\/Frameworks\/CoreFoundation.framework\/Versions\/A\/CoreFoundation",
"name" : "CoreFoundation",
"CFBundleVersion" : "1863"
"source" : "P",
"arch" : "x86_64",
"base" : 140703593648128,
"CFBundleIdentifier" : "com.apple.AppKit",
"size" : 15265792,
"uuid" : "832ad371-d3b8-3061-b4e2-1c4e0cffce0b",
"path" : "\/System\/Library\/Frameworks\/AppKit.framework\/Versions\/C\/AppKit",
"name" : "AppKit",
"CFBundleVersion" : "2113.50.132"
"size" : 0,
"source" : "A",
"base" : 0,
"uuid" : "00000000-0000-0000-0000-000000000000"
"sharedCache" : {
"base" : 140703545520128,
"size" : 15220686848,
"uuid" : "398acfb4-57f6-31e0-bc82-e9959e5c92ce"
"vmSummary" : "ReadOnly portion of Libraries: Total=961.0M resident=0K(0%) swapped_out_or_unallocated=961.0M(100%)\nWritable regions: Total=1.8G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=1.8G(100%)\n\n VIRTUAL REGION \nREGION TYPE SIZE COUNT (non-coalesced) \n=========== ======= ======= \nAccelerate framework 640K 5 \nActivity Tracing 256K 1 \nCG backing stores 2880K 4 \nCG image 32.5M 124 \nColorSync 224K 26 \nCoreAnimation 111.1M 130 \nCoreGraphics 12K 2 \nCoreUI image data 2972K 24 \nFoundation 16K 1 \nKernel Alloc Once 8K 1 \nMALLOC 318.2M 66 \nMALLOC guard page 48K 10 \nMALLOC_MEDIUM (reserved) 944.0M 8 reserved VM address space (unallocated)\nMALLOC_NANO (reserved) 384.0M 1 reserved VM address space (unallocated)\nObjC additional data 15K 1 \nSTACK GUARD 56.0M 12 \nStack 15.1M 12 \nVM_ALLOCATE 18.7M 100 \n__CTF 756 1 \n__DATA 21.4M 369 \n__DATA_CONST 19.1M 223 \n__DATA_DIRTY 913K 134 \n__FONT_DATA 4K 1 \n__LINKEDIT 648.2M 10 \n__TEXT 312.8M 387 \n__UNICODE 592K 1 \ndyld private memory 1024K 1 \nmapped file 144.2M 21 \nshared memory 784K 17 \n=========== ======= ======= \nTOTAL 3.0G 1693 \nTOTAL, minus reserved VM space 1.7G 1693 \n",
"legacyInfo" : {
"threadTriggered" : {
"queue" : "com.apple.main-thread"
"trialInfo" : {
"rollouts" : [
"rolloutId" : "5fc94383418129005b4e9ae0",
"factorPackIds" : {
"deploymentId" : 240000408
"rolloutId" : "60da5e84ab0ca017dace9abf",
"factorPackIds" : {
"deploymentId" : 240000008
"experiments" : [
Model: Macmini8,1, BootROM 1731.120.10.0.0 (iBridge: 19.16.15071.0.0,0), 6 processors, 6-Core Intel Core i7, 3.2 GHz, 64 GB, SMC
Graphics: Intel UHD Graphics 630, Intel UHD Graphics 630, Built-In
Display: onn. TV, 3840 x 2160 (2160p/4K UHD 1 - Ultra High Definition), Main, MirrorOff, Online
Memory Module: BANK 0/ChannelA-DIMM0, 32 GB, DDR4, 2667 MHz, 85F7, J644GU44J9266NQ
Memory Module: BANK 2/ChannelB-DIMM0, 32 GB, DDR4, 2667 MHz, 85F7, J644GU44J9266NQ
AirPort: spairport_wireless_card_type_wifi (0x14E4, 0x7BF), wl0: Jul 12 2021 19:26:30 version 9.30.464.0.32.5.76 FWID 01-45ccefcd
Bluetooth: Version (null), 0 services, 0 devices, 0 incoming serial ports
Network Service: Ethernet, Ethernet, en0
Network Service: Wi-Fi, AirPort, en1
USB Device: Rugged USB-C
USB Device: PSSD T7
USB Device: USB31Bus
USB Device: StudioLive 32
USB Device: USB Receiver
USB Device: T2Bus
USB Device: Headset
USB Device: Apple T2 Controller
Thunderbolt Bus: Mac mini, Apple Inc., 47.5
Ray825
Postby Niffo » 21 July 2022, 11:05
Please try to rename or delete the folder "TheLightingController" in your "home directory".
Postby Ray825 » 21 July 2022, 15:02
Thanks for the reply! I went inside the ShowXpress folder and found a file folder "Thelightingcontoller" and the one I normally click on to start the program same title. It wont let me rename or delete.
Ray825
Postby Niffo » 21 July 2022, 15:55
The folder "TheLightingController" to rename or delete is the one in your "home directory" ("Go" menu in the Finder then "Home")
Postby Ray825 » 21 July 2022, 17:33
Thanks! I think that worked!
Ray825
Return to Mac OS
