Audio synching trouble [fixed]
Postby Romvert » 24 June 2022, 17:48
I'm having trouble inputting audio via cable into the show express software. It seems like it doesn't hear through any other means but the laptop microphone. Is there any way I can get it to do that?
Also trying to understand what the step 3/1 means in beat speed properties.
Romvert
Re: Audio synching trouble
Postby support » 27 June 2022, 08:08
We just added this thread for that: https://thelightingcontroller.com/viewt ... f=7&t=7394
Please watch it.
Postby Niffo » 29 June 2022, 10:51
Here is a thread discussing about this : https://thelightingcontroller.com/viewt ... f=7&t=6474
Postby Romvert » 08 July 2022, 06:04
I'm still not seeing an answer here. What should be input and what should be output? I don't see any options in sound settings to go from an outside input or software, to the show express.
Romvert
Postby support » 08 July 2022, 09:15
The window "Sound Settings" of the Operating System is supposed to list all existing sound equipment of your computer (microphone, jack in, CD-ROM driver, ...). You have to select the chosen one as input.
Postby Romvert » 10 July 2022, 04:37
The only other choice is stereo mix(Realtek audio) which is not recognized by your software.
Romvert
Postby support » 20 July 2022, 14:40
We made a recent test to verify and it straight worked with our setup with the default OS parameters (https://youtu.be/TqsNN418mUw).
But sometimes other OS configurations need parameters and rights managements to be adjusted.
Postby Romvert » 31 July 2022, 01:18
Well, first off all you are playing a track from inside the computer, not the line in. Secondly, looks like your microphone button is pressed, which picks up from the laptop microphone, correct? I tried to run line in and mic button pressed and the software crashes.
Romvert
Postby Romvert » 01 August 2022, 07:36
Bottom line is that I can't figure out how to get scenes to follow just the beat and nor the noted duration. How do I do that?
Romvert
Postby support » 01 August 2022, 16:09
In the screenshot, our software sees the sound from the external 3.5 jack socket. We can plug in this socket either a microphone or a line out from an external music player.
In the video, our software sees the sound from a music played by the Windows music player.
Return to Windows
