different models of fixtures - no pan/tilt shown
Postby jason5d » 13 August 2021, 14:26
Hi
I'm trying to make some generator movement only scenes
with Chauvet trio and robe robin 1200 movers but the pan/tilt channel doesn't show in channels menu
It appears showxpress is combining pan/tilt and ultra pan/tilt on the robin 1200 to make them not combine
any ideas for a work around? maybe alter the personality - I don't use ultra p/t on these big washes
thx
jason5d
Re: different models of fixtures - no pan/tilt shown
Postby support » 13 August 2021, 16:30
Yes, their profiles say they both have the channels:
pan, pan_fine, tilt_tilt_fine
so Generator shows one line for this.
May be the personality file is wrong ?
Postby jason5d » 13 August 2021, 22:59
The personality file is Robin 1200 21ch. I got you to do, can you check please
and trio 15ch.
thx
jason5d
Postby support » 14 August 2021, 13:58
This is because Robin1200 21ch has 16bits pan/tilt channels, while Trio 15ch not (our first test was with the 30ch model).
Our software is presently not able to manage high-res pan/tilt channels with low res pan/tilt channels together.
This is noted.
In the meantime, please use the Trio in high-res pan/tilt mode.
Postby jason5d » 14 August 2021, 14:13
using 30ch mode on the trio's worked
thx.
jason5d
Return to Editor - Generator
Users browsing this forum: No registered users and 34 guests
