In order to help us to fix the problem, could you please try these two 3DView programs from this ZIP file: http://download.thelightingcontroller.c ... w/test.zip
and tell us the result ?
support wrote:Because we are not able to reproduce this problem, we need some more help.
Could you please ?
1. confirm the version of the main program is 9.2.23
2. confirm the version of the 3D program is 5.2.1
3. tell how reacts the view when you rotate it with the mouse/trackpad
4. tell how reacts the view when you resize the 3DView program window
For the two last questions, if possible please post a video.
This should tell us more where comes the problem from.
support wrote:And could you also please try with the previous version of 3DView (we send it to you via email), and let us know the result ?
To do this, we suggest you to:
- rename the current program 3DView by "3DViewNEW" for instance
- copy the old 3DView program in the same folder
Once the test is over:
- delete the old 3DView program
- rename "3DViewNEW" back to "3DView"
Users browsing this forum: No registered users and 45 guests
