Autoupdate BPM window after midi change [fixed]
Postby Paishanu » 07 May 2020, 23:39
Hi everyone, would it be possible that changing the BPM from a midi trigger will update the window that indicates the number of BPM on the Live page?
I have programmed a pad in my DDJ-1000 to be able to put the BPM to the rhythm of each song and it effectively changes correctly, but the number that indicates them does not update until you click with the mouse on the numbers.
It would be a way to make sure that the BPM is correct until you can include Ableton LINK in the next version of your program.
Thank you very much for your constant development !!
Paishanu
Re: Request??? Autoupdate BPM window afer midi change
Postby support » 11 May 2020, 17:25
We are not able to reproduce this with our APC mini. Here the BPM number is refreshed after each new midi trigger.
Could you please post a video showing that problem ?
Postby Paishanu » 11 May 2020, 20:12
Here I leave you a link so you can download the video:
I use a MacBook Pro using MacOS Mojave 10.14.6 and QuickDMX 9.2.14 with the last fix.
http://gofile.me/46152/s9DyIdPv1
Cheers, Paishanu
Paishanu
Re: Autoupdate BPM window afer midi change
Postby support » 11 May 2020, 22:15
Thank you for this clear video.
We are able to reproduce the problem now (we made the first test with a Windows computer).
Noted in our ToDo list.
Postby Paishanu » 11 May 2020, 22:46
Thank you very much!!!
Paishanu
Postby support » 13 May 2020, 13:46
Fixed in the fix file (V9.16).
Re: Autoupdate BPM window afer midi change [fixed]
Postby Paishanu » 13 May 2020, 14:40
You are the best!!!!!
Paishanu
Postby Paishanu » 13 May 2020, 21:47
I have installed the fix, replacing the two executables and also the languages ​​files in the correct paths, but when I start, I get the "efk_hardware" error, is there something I am doing wrong?
Should there be a new efk_hardware file in the fix zip to replace the old one?
Paishanu
Paishanu
Postby support » 14 May 2020, 08:30
This fix works exclusively with the latest complete software setup.
Please install the latest complete software setup (V9.2.10), and then install the fix.
Postby Paishanu » 14 May 2020, 08:37
Thank you, I will try when I finish working and post the result.
Cheers!
Paishanu
Return to Mac OS
