Generator Tab; XY Pant Tilt Issue
Postby PixelClubhouse » 14 February 2020, 06:06
I just got my 512s interface so I can finally start using my lights with ShowXpress. So far everything is going smoothly except for when I use the Generator tab with my Colorkey Mover Halo Spots. All I'm trying to do is create a simple circle in the span of 4 seconds with one static color. When I play it back it runs just fine, the lights follow the route perfectly. The issue appears when I try to save and then reopen the Generator Project or import it into a Live Timeline. All the data saves except for the XY Pan Tilt data which is somehow all of a sudden not selected and the line/curve points are in sporadic places. Any help would be appreciated. Hopefully I explained everything well enough.
PixelClubhouse
Re: Generator Tab; XY Pant Tilt Issue
Postby support » 14 February 2020, 09:55
Please check there is not a negative "shift" (https://thelightingcontroller.com/viewt ... =70&t=6599).
Return to Editor - Generator
