not possible to start some scenes [fixed]
Postby bedo1976 » 09 February 2020, 14:24
Dear Support
I already read different Topics About using zones in ths form. Scenes which are assigned in Zone 1 are working fine, but if I assign Scenes Zone 2,3 or 4 they doesn't start.
I read:
Run more than 3 scenes? [fixed]
Documentation / Instruction for configuring Stand Alone
I discribe here my Project:
1. Number 1 to 6 is assigned Zone 1 (orange) and Number 7 to 12 is assigned Zone 2 (light blue)
2. Button 1 is a Scene moving Moving Heads. Autostart is activated
3. Button 7 is light for the Moving Heads. Here I also tried activating and deactivating autostart, but no Change
4. I use Remote 512 S/N 04313300011400092
5. The Lighing Controller with different versions - now I use 9.2.10 64 Bit from January 2020
6. Windows 10 1909 latest version
If I start SandAlone directly in sweetlight, I can start each Szene well, but also only one
If I close Sweetlight, Remote mode is activated, then only switchin on / off of Buttons which are assigned to Zone 1 are working. I also assigned the Scene from button 7 to button 4 (Szene1) and then it is working.
I also tried to delete all files in remote but it also doesn't solved my issue.
Is it necessary to set proerties that Multi Zone is enabled?
BeDo
[file]
[image]
[image]
bedo1976
Re: not possible to start scene from ZONE2,3,4
Postby support » 09 February 2020, 18:12
Please post a ZIP to download your lightshow (https://thelightingcontroller.com/viewt ... ?f=3&t=168).
We will check that.
Postby bedo1976 » 10 February 2020, 18:42
Dear Support Team
I already uploaded the zip file above the screenshots in "Weihnachtsfeier 2018.zip"
bedo1976
Postby bedo1976 » 10 February 2020, 18:57
I uploaded it again with Scene 1 and 7 with activated AUTOSTART
[file]
bedo1976
Postby support » 11 February 2020, 17:45
The timelines of buttons 5 and 6 are empty ; this is not allowed (https://thelightingcontroller.com/viewt ... =74&t=3637).
Please put at least one scene in the timeline of these two buttons and it will work correctly.
Re: not possible to start scene from ZONE2,3,4 [fixed]
Postby bedo1976 » 11 February 2020, 19:59
Thanks Support
This was the Solution
bedo1976
Return to StandAlone
