request - duplicate universe on 2nd physical output
usb to dmx - 1024 dmx channels
Postby dumbfungus » 07 November 2019, 20:35
Should be a breeze, and sort of surprised it’s not already built in
I have a chauvet xpress1024. One venue that I am headed to set me up in the middle and I have to run DMX in 2 directions.
None of their fixtures overlap addresses, and it all easily fits in one universe.
I would like my USB box to send universe #1 out of both hardware outputs.
dumbfungus
Re: request - duplicate universe on 2nd physical output
Postby support » 08 November 2019, 08:16
Remark noted.
Postby dumbfungus » 17 November 2019, 21:49
Addendum: can we also have a way to merge both outputs into one universe? It would be great for instances when there is no overlap. Otherwise, maybe an option to select priority, if both universes have Data at same addr?
dumbfungus
Postby support » 17 November 2019, 22:40
Could you please explain the purpose of this ?
Postby dumbfungus » 18 November 2019, 14:28
fixtures in a second universe already have scenes. I want to be able to wire them into the first universe. Some smaller gigs it makes more sense. Or is there a way to copy scenes built in Univ2 , and apply them to Universe1?
dumbfungus
Postby support » 18 November 2019, 16:47
To wire the fixtures from second universe to first universe, you have to use the function "Change universe" (right click on the fixture to get this menu).
Then all scenes related to this fixture will automatically play the scene on first universe.
Postby dumbfungus » 18 November 2019, 22:29
Thank you. Excellent tip.
However, it would still be very interested in having universe 1 sent to both physical ports.
dumbfungus
Return to D1024
