Trying to use 3 universes together [fixed]
Ethernet to dmx - web server - 9 buttons - calendar
Postby autogedrocht » 19 February 2019, 11:23
So far:
When i have the 3 Net512 with DHCP, there are 3 universes shown in sweetlight. But my router has some difficulites recognizing them. The router sees 2 Net512 units, but gives 1 unit 2 IP adresses, so in total 3 ip adresses.
When i have DHCP off, and I manually set the 3 Net512 units to different ip adresses (and mac adresses), Sweetlight only sees 1 universe.
I would rather work without DHCP, cause if dont want changing ip adresses and i have to change them in Sweetlight. It needs to be plug & play.
But without DHCP i cant manage to get it working properly with the software.
I use the newest Sweetlight version. I can look up the serialcode, but the units are mounted, so i have to unmount them so see the seriel at the bottom of the device. Unmounting is some work, so i prefer not to when its not necessary.
Are there some settings in the router i should be aware of?
autogedrocht
Re: Trying to use 3 universes together
Postby support » 19 February 2019, 11:32
Please check the interfaces have different MAC addresses.
https://download.thelightingcontroller. ... Net512.pdf
Postby autogedrocht » 19 February 2019, 11:32
Yes, they have it. Like mentioned in my first post.
autogedrocht
Postby autogedrocht » 19 February 2019, 11:35
I made a change in my router. seems to work now :)
Thanks!
autogedrocht
Postby support » 19 February 2019, 11:36
With DHCP off, please try to enter the IP of each interface manually, in the "Preferences" of the software.
Postby autogedrocht » 19 February 2019, 11:50
Yes, that works.
Thank you very much.
autogedrocht
Return to Net512
