problem with Ssa
usb to dmx - 19'' rack - 16 flash buttons - dmx input (2003 - 2010)
problem with Ssa
Postby Wille » 17 February 2019, 20:11
hi i have borrowed a ssa that i will fix but i dont get it to work. The symptoms are that it cannot be saved on Ssa. sometimes when it is possible to save the X and Y movement is uneven and the color flashes or changes. on the moving head I have used.
And if I use an LED lamp then it will be the same error. So I have some questions that can help me.
1. Does a Ssa work with sweetlight version 9.1.9?
2. Is there any type of battery in Ssa that may have become bad so it does not work properly?
3. Is it for DMX speeding up to it?
Wille
Re: problem with Ssa
Postby support » 17 February 2019, 22:57
It is supposed* to.
*supposed because of 9 years of computer (usb) technology difference
For standalone, please use the latest fix (https://thelightingcontroller.com/viewt ... f=2&t=5922).
No.
Sorry but we do not understand this question.
Postby Wille » 18 February 2019, 14:37
DMX speed is it the same today and 10 years ago?
Wille
Postby support » 18 February 2019, 16:33
It is 20Hz for the software channels refresh.
It is 35Hz for the dmx signal refresh of the existing dmx interfaces (D512/Remote/Rack).
It is 10Hz for the standalone channels refresh.
Postby Wille » 18 February 2019, 21:08
ok i got it working now thanks. but do you know how you can play scens on ssa without it looping?
Wille
Postby support » 19 February 2019, 08:35
As workaround, we suggest you to had some steps at the end of the scene.
Postby Wille » 19 February 2019, 16:49
ok. Is it possible to use 2 buttons at the same time
like controlling a moving head colors with 1 and 2 and then controlling a LEDcan colors with 3 and 4 at the same time?
Wille
Postby support » 19 February 2019, 18:45
Yes, this is possible.
You have to fix a different zone for buttons 1-2 and buttons 3-4.
Postby Wille » 19 February 2019, 20:48
ok thanks one more thing dose it exist somesort of user manual to the Ssa?
Wille
Postby support » 19 February 2019, 22:29
There is no specific manual.
If you have a question, please ask.
Return to Ssa
