Virtual dimmer channel (dimmer for RGB)
Postby Bakkster » 04 September 2017, 18:29
Is there a way to create a 'virtual dimmer' which can be automated to act as a dimmer channel for 3-channel RGB fixtures?
Bakkster
Re: Virtual dimmer channel
Postby support » 04 September 2017, 20:42
Sorry but we do not understand your question.
Postby JohnRichards » 04 September 2017, 21:28
You can assign the channels of the rgb fixture to one of the master faders.
John
JohnRichards
Postby Bakkster » 10 September 2017, 20:49
support wrote:Sorry but we do not understand your question.
I'm hoping to create a fixture that the software treats as 4-channel RBG+Dimmer, but gets output to DMX-512 as 3-channel RGB only? In other words, control a typical RGB LED tape as if it were a 4-channel fixture.
JohnRichards wrote:You can assign the channels of the rgb fixture to one of the master faders.
John
I'm having difficulty finding how to assign the master faders. Can they be automated with macros?
Bakkster
Postby support » 10 September 2017, 21:32
Understood, so the answer of JohnRichards is correct.
https://thelightingcontroller.com/viewt ... =72&t=3647
Postby Bakkster » 11 September 2017, 01:05
Can master faders be automated with macros?
Bakkster
Postby support » 11 September 2017, 08:25
No.
The Master Fader acts over all buttons.
Re: Virtual dimmer channel (dimmer for RGB)
Postby joshjosh » 04 February 2019, 14:39
Has anyone been able to figure out how to create a virtual dimmer yet? I am also stuck needing a "virtual dimmer" channel for my LED strips with 3ch decoders. I have been able to find other lighting controllers that are starting to add this feature. Is this something that could be done in ShowXpress? It would be huge!!!
joshjosh
Postby support » 04 February 2019, 15:10
So far, a Master Fader can do the job.
Postby joshjosh » 04 February 2019, 23:10
Can you use the master fader in the steps editor?
joshjosh
Return to Editor - Fixtures
Users browsing this forum: No registered users and 43 guests
