pan tilt cue stacks like sine & saw
Postby jason5d » 31 January 2019, 13:21
I had a go on a Grand MA lighting controller this week and the LD had cue stacks to busk with set up as such;
Pan and tilt were separate and each movement could select between different wave forms such as sine, step & saw
Can I do something similar with some generator programs?
any thoughts?
jason5d
Re: pan tilt cue stacks like sine & saw
Postby support » 31 January 2019, 15:30
Basically, our choice was to give the possibility to draw any curve you want. So pan & tilt are always displayed together on a X/Y section.
To move only pan or tilt, you can put all points on an horizontal or vertical line.
And you can use the option "Lock Pan or Tilt' for more ease to put the points.
Return to Editor - Generator
