Mutiple buttons selection for color palette [fixed]
Postby Bobnjul » 29 January 2019, 19:25
Not sure if this is a bug or just an annoyance, but I was wondering if in an update you could address the fact that, at least on a Mac, when choosing button colors... on the button that the Color palate is selected (via right-click menu) the arrow on the "Light/Dark" slider bar is set to 127, but if I select another button without closing the palate, the arrow on the Light/dark bar jumps to 255... it a bit of an annoyance to have to drag it back to 127. While you're at it, it would be awesome if we could select multiple buttons to color simultaneously if they are all to be the same color, and it would also be fantastic if we could some how save frequently used colors so they could be reselected quickly.
Thanks,
Bob
Bobnjul
Re: Button Color Palette
Postby Gilles » 30 January 2019, 07:29
Gilles
Postby support » 30 January 2019, 16:55
In fact, this is the level "127" which is bad.
With a not colored button, the default level should be "255". We will note that in the ToDo list.
For multiple buttons selection, you have to use the key "ctrl" + mouse click, after the "Button color" window has been opened.
Re: Color Palette for mutiple buttons [fixed]
Postby Bobnjul » 30 January 2019, 17:52
Wow! thanks for the note on the multi-select! I had no idea! I just tried it - On mac, it's command.
Bobnjul
Postby Gilles » 30 January 2019, 18:04
Super ;)
Gilles
Re: Mutiple buttons selection for color palette [fixed]
Postby support » 30 January 2019, 18:22
Yes, "ctrl" for Windows and "command" for MacOS.
Return to Live - Buttons
