Adding a button stops the other running buttons
Postby Absoliutas » 17 December 2018, 19:11
Hello
When running a show in Live mode, sometimes i need to go to editor>steps and make a new steps scene or generator project. Problem is, that adding a saved scene or generator project to live (as a button), live mode begins to act this way - runs only one button, and all other button stops running. I mean, that in live starts working only ONE button. Pressing another button, releases all other buttons (only one saved scene can be played). The problem can be solved only turning software off and then on again. Then all buttons in live starts act as normal - you can turn on as many buttons as you want.
Tested on several computers, the problem is the same.
Working on windows 10, 64bit.
Absoliutas
Re: problem with live
Postby support » 18 December 2018, 09:04
We are not able to reproduce that, with version 9.1.9.
Please check you are using V9.1.9 or later.
If yes, please post video illustrating this problem.
Postby Focu » 20 December 2018, 15:41
Here's a video. I apologize in advance for the quality. The bottom line is that when you activate the button, the other buttons turn off.
This is the latest version of software.
https://drive.google.com/open?id=1EV9Ow ... WUwk0PqYwR
Focu
Re: Adding a button stops the other running buttons
Postby support » 20 December 2018, 16:46
Your video starts by showing the "bad working" state ; it does not explain to us how to reproduce the problem.
We would like the video starts with the "good working" state, and then the required action to make it "bad working", and then the "bad working" state.
Postby Focu » 20 December 2018, 18:19
support wrote:Your video starts by showing the "bad working" state ; it does not explain to us how to reproduce the problem.
The fact is that it manifests itself randomly. That is, for some time the program works well, but at some point after editing a scene or adding a new button (not every time) it starts to work inadequately (any button starts to work inadequately)
Focu
Postby Absoliutas » 20 December 2018, 18:48
The same to me. Not always program bahaves in this way, but quite often, most likely after creating genarator project and adding it to live as a button. I will upload full video soon.
Absoliutas
Postby Absoliutas » 20 December 2018, 20:10
Here is a full video with fully working live, then after creating generator scene and adding it to live, the live mode begins to work with only one button, all other buttons are released. Reboot resolves the problem. Using latest 9.19 version
Video: www.aktualu.lt/quick-dmx-problem.mp4
Absoliutas
Postby support » 21 December 2018, 10:29
Thank you for this clear video.
Could you please post also a link to download this lightshow ?
Then we will have all to reproduce the problem here.
Postby Absoliutas » 21 December 2018, 12:46
Hello. Here is full lighthsow:
www.aktualu.lt/TheLightingController.zip
Absoliutas
Postby support » 21 December 2018, 18:25
Thank you, but it is slightly different than the lightshow from the video.
Don't you have the same lightshow than in the video ?
Return to Live - Buttons
