generator manual bpm
Postby lesley » 22 November 2018, 19:04
Is there a way to make the movements made by the gernator or show creator sound controlled?
I found a way Stand alone mode> create steps file but this is verry unstable (generator project with a short duration will not save as steps file)
It would be nice if there were checkboxes in the generator in wich you could choose wich aspect was aviable for sound contoll like movement or color.
I already searched the forum.
lesley
Re: generator manual bpm
Postby support » 22 November 2018, 19:09
This is unfortunately not possible for this reason: https://thelightingcontroller.com/viewt ... 820#p23741
Postby lesley » 22 November 2018, 19:33
support wrote:This is unfortunately not possible for this reason: https://thelightingcontroller.com/viewt ... 820#p23741
This is why I state:
Everthing would stay the same with the exception that one of the aspects like movement is bpm/sound controlled as a hard setting for the project.
The power of sweetlight for me is that I can let it run in the background without making adjustments ervery few minutes, sound controll helps to achieve this.
lesley
Postby support » 23 November 2018, 20:51
In our opinion, the best way is to program pan/tilt movements with generator, and color changes with Steps.
Return to Editor - Generator
