Crash when selecting mono + multi heads fixtures [fixed]
create scenes with steps
Postby sgriffin1 » 27 October 2018, 19:18
Using 4 Intimidator Spot 455's and also 2 Intimidator Spot Dou 155's. Every time I select all these fixtures in steps, then try to position them, program crash....
sgriffin1
Re: Version 9 repeated crash
Postby support » 27 October 2018, 22:16
Please post a link to download your lightshow (https://thelightingcontroller.com/viewt ... ?f=3&t=168).
We will check that.
Postby support » 30 October 2018, 22:17
Thank you for your lightshow.
Fixed in the fix file (https://thelightingcontroller.com/viewt ... =85&t=3438).
Re: Crash when selecting mono + multi heads fixtures [fixed]
Postby sgriffin1 » 30 October 2018, 23:47
Thanks for checking out the problem! I am very happy with v9. I have run this version for several 4 plus hour shows with no problems. Just happened to find this one problem and wanted to let you guys work you magic on it. Keep up the good work!!!!!
sgriffin1
Return to Editor - Steps
