graphic issues in v9 3dview
Postby cas » 06 August 2018, 10:59
i'm on windows 8, v9 beta, 64 bit.
this is the problem:
happens with every color
these are my settings:
when i turn gobos off, the problem is gone, (even though these fixtures are rgb pars) and when i check opengl compatibilitymode, the problem is also gone, but i believe that's the old 3dview.
the problem does not occur when using moving heads on open, but when i use a gobo with gobos enabled in the settings, the problem does occur.
cas
Re: graphic issues in v9 3dview
Postby support » 06 August 2018, 14:25
Please update the driver of your video card, and let us know the result afterwards.
Postby cas » 06 August 2018, 16:47
support wrote:Please update the driver of your video card, and let us know the result afterwards.
i've installed the latest drivers for my graphics card, but the issue unfortunately remains.
cas
Postby BartKrap » 06 August 2018, 17:27
What video card do you have. It looks like an issue often found on fake cards that claim that they have more onboard video memory than is really on the card.
BartKrap
Postby cas » 06 August 2018, 17:33
BartKrap wrote:What video card do you have. It looks like an issue often found on fake cards that claim that they have more onboard video memory than is really on the card.
I don't exactly know which video card, but it is an internal video card in my hp laptop, which is a couple of years old now. i don't think the issue is having too little memory, because v8 3dview works fine with large amounts of moving lights and pars, and the new version also works fine, I just get the weird graphics issue.
cas
Postby Gilles » 06 August 2018, 19:55
Etrange, je retrouve le souci de scintillement que je rencontre.
Voir le sujet ci dessous en milieu de page.
https://thelightingcontroller.com/viewtopic.php?f=13&t=5700
Gilles
Postby cas » 06 August 2018, 20:24
some more pictures:
moving head no gobo/open:
now with any gobo i've tried so far:
cas
Postby ineedabeatdj » 20 September 2018, 12:32
Mine was not working either. When I checked OpenGL compatibility mode it started working.
ineedabeatdj
Postby cas » 29 September 2018, 14:42
ineedabeatdj wrote:Mine was not working either. When I checked OpenGL compatibility mode it started working.
With opengl checked you're just using the old 3dview
cas
Postby support » 12 October 2018, 09:34
Could you please try with these updated gobo files: http://download.thelightingcontroller.c ... /gobos.zip
(you have to replace them in the folder "../YourSoftware/3DView/")
and let us know the result ?
Return to 3DView
