Color changes in 3d viewer [fixed]
Postby djayabsolute » 09 August 2018, 07:17
I'm new to showxpress and having an issue with the lights changing colors in 3d viewer. I built the light profile and for some reason the dimmer works but i can't get it to change colors. I have attached the txt file with this message. Please help and thank you.
eyourlife stage light par led 60w.txt
(860 Bytes) Downloaded 671 times
djayabsolute
Re: Color changes inn 3d viewer
Postby marco » 09 August 2018, 09:00
There are som fault in you profile
The channel for red shouldn't be named color but needs to be named red
The channel for green shouldn’t be colr but green
The channel for bleu shouldn’t be color but blue
The channel for with shouldn’t be color but white
The easiest way is to select the correct funtion in fixture editor
Or even easier post the manuaal and support will provide the correct profile
Please read: https://thelightingcontroller.com/viewt ... f=3&t=2453
Youtube : https://youtu.be/C2CIVpMRnvo
marco
Postby Gilles » 10 August 2018, 06:31
Essayer ça devrait fonctionner.
(779 Bytes) Downloaded 676 times
Gilles
Return to 3DView
