V9 Gobo Graphics Glitch
Postby SeekLighting » 06 July 2018, 03:03
Hi Support
Found a slight graphics glitch with a few gobos in V9. Please see the video below:
https://www.youtube.com/watch?v=nFMOGdnzrx4
FYI I demonstrate the glitch at about 30 seconds in.
This glitch only occurs with one or two gobos, but you can see it clearly creates a large, very strange reflection around the room.
I am running a NVidia Geforce GTX 960M, with the software running Open GL, in mode "Phong".
I brought this up in Alpha but forgot to post the video. Hopefully it is of some use to you now anyway :)
Regards
Tim H
Re: V9 Gobo Graphics Glitch
Postby Gilles » 06 July 2018, 07:53
Bizarre ce reflet, mais la version 9 est disponible?
Je ne la trouve pas sur le site....
Gilles
Postby LightningFM » 06 July 2018, 10:02
I'm having the same issue with the gobo Z03748-12. However, I'm experiencing a slightly different reflection.
I'm running with Phong render mode (but the glitch is visible also in the other modes) on a Nvidia graphics card as well, Windows (64 bits).
Screenshot (with current settings and software version): https://imgur.com/a/WLIsuu9
@Gilles: V9 is now Beta, you can find it in the "Announcement" section https://thelightingcontroller.com/viewt ... f=2&t=5690 ;)
LightningFM
Postby support » 06 July 2018, 10:29
Yes we saw your first post and we already checked that.
In fact 3DView uses a known and recent 3D API to display the textures.
In other worlds, it just calls a function "show texture".
And unfortunately, we are not able to reproduce this problem with our 3D cards.
Could you please check the picture of the gobo with the problem, and confirm that it borders are 100% in black color (RGB = 0xffffff) ?
Or if you see any other difference with a working gobo, and a non working gobo.
Postby LightningFM » 06 July 2018, 11:08
Hello Support,
I noted that the border of Z03748-12 actually has a little white dot on the left-down corner.
While scrolling the other gobos I also noted that some other gobos (like SH5) have up to two corners fully white arising bigger reflections.
I'm attaching the original gobo files.
I'll try repainting the borders to see if that can resolve the issue
LightningFM
Postby Gilles » 08 July 2018, 06:14
LightningFM wrote:@Gilles: V9 is now Beta, you can find it in the "Announcement" section https://thelightingcontroller.com/viewt ... f=2&t=5690
Super, merci ;)
Gilles
Postby Gilles » 08 July 2018, 16:03
J'ai le même genre de soucis avec des gobos et lyre led RGBW.
Est ce que ça vient de mes paramètres ?
Désolé je ne sais pas comment reduire les photos
Gilles
Postby Gilles » 10 July 2018, 07:04
J'ai trouvé, il faut cocher Chk OpenGLCompatibility.
Gilles
Postby support » 10 July 2018, 11:01
Ce paramètre permet de forcer l'utilisation de l'ancien moteur 3D (V8).
C'est l'ultime solution, lorsqu'il y a des problèmes avec la carte vidéo.
En revanche, on constate dans votre screenshot que les textes ne sont pas correctement affichés ; si le langage du logiciel est réglé sur "Français", ce n'est pas normal.
Postby Gilles » 10 July 2018, 12:38
Ah d'accord, donc ma solution n'est pas correcte.
Oui, le langage est le français. J'ai installé la version 64bits windows 10.
Ma config si besoin:
MSI intel core i7-6700HQ CPU 2.6 GHz
Windows 10
RAM 16 Giga
Nvidia GTX 970m
Pour le moment, je n'ai pas installé les drivers 2018, je teste la V9 avant de l'adopter ;)
Pouvez vous m'orienter?
Gilles
Return to 3DView
