V9 beta - enter step duration affects the next step [fixed]
create scenes with steps
Postby thorehl » 02 July 2018, 19:04
Hi. Having trouble changing Duration time and Total duration time.
Tab out, Enter, Clicking somewhere else work about 10% of the time. It's as if it doesn't want to change
Thore
Using HW: D1024 & D512
Controller: 2x Akai APC mini
my DIY light mixer
thorehl
Re: Duration - V9 beta
Postby support » 05 July 2018, 15:06
We are presently not able to reproduce that.
Please confirm:
- your Operating System
- your software version (32bits or 64bits)
And if possible, please post a Youtube link of a video showing the problem.
Postby LightningFM » 06 July 2018, 12:23
I'm having similar problems as well with the step duration: see this https://youtu.be/8dTlwkcE0mA (unlisted)
In that example scene, originally all steps were created with the shortcut CTRL+"+"; they were initially set to last 00:00:30 each, after a couple of run with no issues I changed the step duration to two seconds only in "Red2".
The change in duration appeared to affect the "white" step.
Earlier today I noticed similar issue also while programming other scenes with blinders, in some cases certain steps were even skipped.
I'm using Windows 10 and SweetLight 64 bits.
LightningFM
Postby support » 06 July 2018, 16:48
Thank you for this clear explanation.
Fixed in the "fix" file.
http://download.thelightingcontroller.c ... ew/fix.zip
Re: V9 beta - enter step duration affects the next step [fix
Postby LightningFM » 06 July 2018, 16:53
Thanks!
Checking it right now :)
LightningFM
Postby LightningFM » 06 July 2018, 19:07
Hello Support,
I created some scenes and the fix file apparently solved the issue initially, but now I'm encountering the problem again.
I made a scene in Generator and converted it in Steps. At "Step 15" I changed the duration a couple of times and then I noticed no apparent change. The step is supposed to last 00:00:10 but instead it takes much more time.
LightningFM
Postby thorehl » 07 July 2018, 09:39
I am currently using
Windows 10 - 64bit
Sweetlight 64-bit
Youtube link: https://youtu.be/FfSNcbhjMMA (unlisted)
Tried applying the fix.zip 9.0.2beta2 but same issue as in the video
Thore
my DIY light mixer
thorehl
Postby support » 07 July 2018, 10:52
Problem of "total duration change" noted.
Postby support » 04 August 2018, 15:27
Postby support » 08 August 2018, 15:41
No.
Mistake.
Please wait.
Return to Editor - Steps
