I do not see the fixtures [fixed]
Postby Focu » 04 July 2018, 08:28
When I open 3d renderer I do not see the fixture but the fixtures setting tab is not actin. :(
[image]
Focu
Re: when you activate the 3d version of V8, you can not see
Postby support » 04 July 2018, 09:15
Looks like firewall/antivirus blocking problem.
Please read this: https://thelightingcontroller.com/viewt ... f=13&t=834
Re: I do not see the fixtures
Postby Focu » 04 July 2018, 10:19
it did not work, I tried to disable the firewall, create new rules, remove the full program and re-install, nothing happens.
so I installed v9 there fixtures are visible but I can not manage them.
Focu
Postby F.SEGUIN » 04 July 2018, 15:45
In the fixture setting, dbClick on "Moving ligt spot" for open the Device editor and look if the 3D view is selected with a device. If the 3D view selected is "not in 3DView" The device is not displayed in the 3D view.
F.SEGUIN
Postby Focu » 04 July 2018, 16:51
No, the device is not visible
Focu
Postby Focu » 08 July 2018, 08:45
I found a solution. Just need to change the ip address to 127.0.0.1. Maybe someone it will be useful. ;)
Focu
Postby support » 08 July 2018, 09:13
Thank you for the feedback.
This IP address is supposed to be the default IP address in the software parameters.
Please let us know if it was another IP address after first software installation.
Re: I do not see the fixtures [fixed]
Postby Focu » 08 July 2018, 13:19
I'm not sure that this is a problem in v9 because on the other computer it was all good
Focu
Return to 3DView
