Can you use a external 3d view?
Postby Mashout » 28 May 2018, 17:52
HI all,
Can we use a external 3d vieuw like Capture via Artnet?
Greetings,
David
Mashout
Re: Can you use a external 3d view?
Postby support » 28 May 2018, 21:01
Our software is able to output the dmx channels via Artnet.
Beyond that, we do not know.
Postby BartKrap » 30 May 2018, 10:25
Mashout wrote:HI all,
Greetings,
David
Yes you can via artnet in on Capture. Just note that you do need to at least one interface connected to be able to output artnet.
BartKrap
Postby Shakes » 28 September 2018, 22:51
BartKrap wrote:Yes you can via artnet in on Capture. Just note that you do need to at least one interface connected to be able to output artnet.
When you say one interface, is that an Artnet interface or a lighting controller DMX interface??
Shakes
Postby SeekLighting » 29 September 2018, 04:50
You always need a Lighting Controller interface to unlock output. One Interface connected provides 2 universes - one over the interface via DMX and another via artnet, output from the Computer's Ethernet port. You would need to purchase an artnet node to convert this artnet signal back to DMX.
Return to 3DView
