CHROMA Q - INSPIRE
CHROMA Q - INSPIRE
Postby pogjack » 15 March 2018, 17:34
I have 41 Chroma Q inspire fixtures in my sanctuary. I have mapped them on pixels and did some effects which work fine. I added LED Strip tape on the underside of our stage and have it where I can control 16 different sections of it. I have also mapped them to the pixel page along with the Inspire.
I moved the strip tape to the top of the screen so I can select only them to do effects and not the inspire, but whenever I do an effect with just the strip tape, it causes the Inspire to lose the red LEDs which is noticeable (RGBW fixtures - all are on for bright white and when Red is gone there is a noticeable difference).
What causes this to happen. I cannot determine how to move the pixel program to editor so I can look at each individual light so I can't tell what's going on.
Is there a way to have different pixel maps (ex. just the Inspire, then just the LED strip tape)?
thanks,
pogjack
Re: CHROMA Q - INSPIRE
Postby support » 15 March 2018, 18:57
Please check the dmx addresses of all fixtures in Pixels.
If there any overlap, this will cause such problems.
Postby pogjack » 15 March 2018, 19:44
I’ve done that already. There is no overlapping.
Is there a way to view the steps for a scene that is causing the flickering so I can inspect each light?
pogjack
Postby SeekLighting » 15 March 2018, 21:49
You can import your pixels scene into Standalone mode and from there export it as a Steps scene. This will allow you to open it in Steps mode and inspect it. If you need help to do this: https://thelightingcontroller.com/viewt ... =70&t=4367
Return to Pixels
Users browsing this forum: No registered users and 20 guests
