beams not showing in 3D view
Postby BSOR » 05 December 2017, 16:09
Help requested please. The beams from my moving heads (JB systems Sirius) do not show up in my 3D screen. All beams from my other lights are visible (washes and floor floods etc) The 3D render showsthe moving heads moving as per the scene but there is no light beam shown. What am I doing wrong? Thanks in anticipation
BSOR
Re: beams not showing in 3D view
Postby support » 05 December 2017, 17:17
Please post the personality file.
(Tab "Editor > Fixtures" > double clik on the fixture > click on "Export" in the window "Edit Fixture")
We will check it.
Postby BSOR » 06 December 2017, 12:49
Atomic 4DJ.txt
(497 Bytes) Downloaded 729 times
JB Systems Sirius.txt
(483 Bytes) Downloaded 730 times
Here are the personality files from my two different moving heads - neither display beams in 3D view. Thanks in anticipation
BSOR
Postby support » 07 December 2017, 09:24
The channel "shutter" must have at least one level with the name "open".
The channel "color" must have at least one level with the name "white".
The attached revised profiles show a white beam.
If you make the profiles requirements here: https://thelightingcontroller.com/viewforum.php?f=25
following this: https://thelightingcontroller.com/viewt ... f=3&t=2453
we will do the complete personality files for you.
(508 Bytes) Downloaded 701 times
Atomic 4DJ.txt
(522 Bytes) Downloaded 722 times
Return to 3DView
