live quits show xpress on mac
Postby jason5d » 10 July 2017, 14:51
Show Xpress abruptly quits when i use it with live mobile after several program changes.
2014 fully loaded macbook pro running el cap 10.11.6 and showxpress (latest version downloaded from this forum)
htc one phone running 4.4.2
connected via router
jason5d
Re: live quits show xpress on mac
Postby support » 11 July 2017, 11:32
Please post a download link of your lightshow.
We will check that.
Postby jason5d » 13 July 2017, 23:08
jason5d
Postby support » 14 July 2017, 16:41
The folders of your lightshow are corrupted.
All folders are doubled with a capital and a normal first character (like for instance "Generator" and "generator").
Please watch our demo lighthow, and change the names of the folders like they are in the demo lightshow, and remove the other folders.
https://thelightingcontroller.com/viewt ... =85&t=4556
Postby jason5d » 14 July 2017, 17:56
I'm not seeing the extra folders in the first folder
I have looked on a mac and windows.
compared to the demo the file count is 1 more
here's a picture of both folders
https://www.dropbox.com/s/4naqzlrlf9owd ... 7.png?dl=0
it might be easier if you correct the folder and re post it back, then I can see the difference.
Thx. for you help
jason5d
Postby support » 15 July 2017, 10:49
So this might be due to the way you sent the files.
Please try again like this:
- first make a zip file of the entire lightshow folder
- then post the zip file via Dropbox
Postby jason5d » 15 July 2017, 12:35
here's the zip file link
https://www.dropbox.com/s/ts2tlortnla9k ... 7.zip?dl=0
Looks like this issue causes the application to crash when I try to open the window to edit midi sliders
jason5d
Postby jason5d » 15 July 2017, 17:21
i have a show tonight and i'd rather not use the pearl tiger for a club night.
I though i might rebuild the document by moving parts over a few at a time to see what might be causing the issue.
i copied "fixtures midi inputs" and it crashed when i opened it the window. then i deleted the file the window opened ok - ill have to re-set the midi sliders
i will see if the mobile app works ok this eve
jason5d
Postby jason5d » 16 July 2017, 03:35
live app still crashes show xpress
jason5d
Postby support » 17 July 2017, 16:43
We are not able to crash the software by using the app, with your lightshow.
There should be something special to do.
Please post a video showing the crash.
Return to Android
