Problems with Colorband PIX M USB and Generator
Postby Cajunguy » 09 February 2017, 13:02
There seems to be an issue using the colorband pix m usb with the generator. If I try to generate any thing with changing colors (other than default colors of generator) the fixture is a little buggy. For example if I try to generate something with blue red and purple the fixture won't show those colors. Am I missing something?
Cajunguy
Re: Problems with Colorband PIX M USB and Generator
Postby BartKrap » 09 February 2017, 14:34
Is this in 3d or when looking at the physical fixture?
BartKrap
Postby Cajunguy » 09 February 2017, 16:06
Physical fixture
Cajunguy
Postby Cajunguy » 13 February 2017, 14:27
Is anybody else having this issue?
Cajunguy
Postby BartKrap » 14 February 2017, 08:06
Cajunguy wrote:Is anybody else having this issue?
I don't have this fixture, but could maybe make a video showing the problem, that should allow me to better understand the problem.
BartKrap
Postby Cajunguy » 17 February 2017, 15:26
I just got around to it, sorry. I really appreciate your help. I hope you can understand what I'm saying. Real heavy Cajun accent, lol.
https://youtu.be/QX6zemwmrhg
Cajunguy
Postby support » 17 February 2017, 18:52
Thank you for this video.
Looks there is effectively a problem.
We will come back to you regarding this, asap.
Postby Cajunguy » 17 February 2017, 21:22
support wrote:Thank you for this video.
Thanks for the response. Just to let you know, I've tried building profiles from scratch, and also tried adapting other profiles, such as profiles for Colorband PIX M. I've just run out of options. Until I can get a fix I'm forced to use this fixture as single rgb unit (boring). lol It does have a few nice auto presets though. But that'll get old quick. :)
I bought 12 of the fixtures. It'll be awesome when I can get them working correctly. Again, thanks for the help.
Cajunguy
Postby BartKrap » 18 February 2017, 14:00
This is a pretty simple fix.
You have to disble the green on ALL the rgb lights, not just the first and check all; go trough ALL RGB options and delete that green point.
Then it should work,
Also I recomend using pixels for multi RGB fixtures.
By the way, that light you called the last light, is actually the first.
BartKrap
Postby support » 18 February 2017, 18:37
After double-checking, there is effectively no problem ; "BartKrap" is right.
And we also recommend to use Pixels for multi-pixels fixtures.
Return to Editor - Generator
