Colors of buttons are not correct
Postby Light_user » 27 December 2016, 16:39
When assigning a color to a button, the result is not the color i selected. For example when selecting "strong Blue" the result is light blue on the button.
Edit: also when creating a colored image (for example in microsoft paint) with a fixed color and using it as button image in the live view, the result in the live view is not the color i created.
Light_user
Re: (Bug): colors in Live View are not correct
Postby support » 27 December 2016, 17:26
This is normal.
There is an additional "bright" layer over the color, in order to always be able to read the text in the button.
Postby Light_user » 08 January 2017, 02:32
That can be done with drop shadow behind the text or something. Or only placing a layer behind the text, not on the whole button.
When having multiple premixed colors (for example Dark blue, Light Blue, Purple, Purple-Red) it's almost impossible to visually see the difference on the screen in the current situation. All color differences are dissapearing because of the extra layer.
Light_user
Postby Lighter007 » 14 January 2017, 21:06
I see your problem. What about a white or lighter colored rectangle behind the text? Or a color transition from light color in the center (where the text is) to original color at the outer side of the button?
Greetings from Germany! :)
Lighter007
Postby support » 15 January 2017, 18:07
Visible text is not the only issue.
Capture du 2017-01.png (2.89 KiB) Viewed 7230 times
Return to Live - Buttons
Users browsing this forum: No registered users and 20 guests
