"timeline" button flashes off lights
Postby James » 22 November 2016, 17:49
Example I have a blue LED Par light scene to walk onto stage to.
Press Button to start track and light sequence, as button file loads, lights go out in latest version?
If I click into Timeline to play in works fine
Older versions of software worked fine as well.
If I add the Blue scene button to beginning of track, lights still go out when the file loads?
any ideas
many thanks.
James
Re: Button now Flashes off lights
Postby support » 23 November 2016, 08:08
Please tell the exact version number.
Postby James » 25 November 2016, 01:46
Sweetlight 8.1.29
James
Postby support » 25 November 2016, 07:59
Please send your lightshow (viewtopic.php?f=3&t=168), and tell us how to reproduce this problem.
We will check that.
Please tell us also the version number of your previous software, with your lightshow was working fine which.
Postby James » 27 November 2016, 15:18
Recently sent you a lightshow (Massive Delay in Timeline)
Simply create a button to trigger a scene, switch a par on a stay on as an example
then have another Button to trigger a Timeline, as the file loads the original Par will go out
My laptop had installed an earlier 7 Version.
These earlier versions kept the lights on perfectly switching between timelines
problem with this latest version is that this bug switches all stage lights off every time I load a Timeline plunging me in total darkness...
James
Postby support » 28 November 2016, 08:41
In your lightshow, we added a new basic RGB fixture.
We made a one step scene with it (always red).
We added a button in Live for this scene.
We switched it on.
Then we press the timeline button which triggers your big timeline.
And we are not able to see the problem. By watching the dmx bargraph and 3DView, the RGB fixture seems to be always on.
Postby James » 29 November 2016, 00:45
With actual DMX lighting connected the lights go out
Installed latest 8 version software on 2 different PC's - one Desktop and one laptop and lights still go out
Installed an earlier 7 version back onto Laptop and lights stay on as they should
They go out as timeline file loads
Will have another look, but looks like I will have to stick with the earlier 7 version for now
James
Re: "timeline" button flashes off lights
Postby James » 05 January 2017, 16:25
Hi Cleanly installed latest version (8.2.10)
The flash bug is still in here?
If I have a simple scene switched on (so I can see stage with LED Pars)
and I click to play my Button timeline all the lights go out for a second before timeline starts, no matter what I do, I can have the same scene at the beginning of the timeline, they still go out.
This is in the BUTTON section, If I go into the TIMELINE panel with the same loaded file and with the original Stage Lit scene on it works fine, no flashing so it is within this Button section
Any ideas how to cure this?
many thanks
James
Postby James » 05 January 2017, 16:34
This BUTTON light off bug seems to be when the file is loading
If I have a particularly large file loading the lights will actually flash slowly on and off whilst the file loads, then starts and works as normal.
James
Return to Live - Buttons
