[MacOS] "Midi learn" works, but no button's trigger [fixed]
Re: Lighting Controller Crashes EVERY TIME it's opened!
Postby Niffo » 28 October 2016, 22:47
Probably fixed in next fix file.
Postby benschrade » 28 October 2016, 23:22
Great! What is the timeline for the fix file?
benschrade
Postby support » 30 October 2016, 10:11
It is on line (V8.1.30).
Please try it and let us know.
Postby benschrade » 31 October 2016, 17:24
http://download.thelightingcontroller.c ... ew/fix.zip
I downloaded the fix.zip from the link above. It is unable to open, displaying "efk_hardware" not found.
I am currently running El Capitan. What should I do?
benschrade
Postby benschrade » 31 October 2016, 17:32
My apologies. I got it to work.
I currently have it up, but am still unable to launch the MIDI cues successfully.
Able to 'learn' the cue and auto fill all the correct information, but doesn't not depress the button, launching the scene, when the cue is given.
benschrade
Postby Niffo » 31 October 2016, 17:43
benschrade wrote:Able to 'learn' the cue and auto fill all the correct information, but doesn't not depress the button, launching the scene, when the cue is given.
Please check you are using V8.1.30. In this version, midi is supposed to work exactly like in 8.1.0.
Postby benschrade » 31 October 2016, 18:13
Currently using 8.1.30. No luck.
benschrade
Postby benschrade » 04 November 2016, 00:18
What is the next step?
benschrade
Postby BartKrap » 05 November 2016, 12:00
benschrade wrote:What is the next step?
Maybe it's not a problem with the lighting controller, when's the last time you've updated the drivers of your midi devices?
BartKrap
Postby benschrade » 05 November 2016, 13:24
I haven't, specifically. I will try, but I'm doubtful this will correct anything.
The program is able to "learn" the MIDI commands, meaning that The Lighting Controller is hearing the command and the MIDI is functioning. I've tried with other MIDI devices as well, immediately after drivers were installed.
benschrade
PreviousNext
Return to Midi
