If I look at all these faults and it is not a cable fault or box fault it can only be 2 other possibilities.
1 - Driver not the correct driver
2 - Incompatible usb 3 port.
I would suggest you try and install on an old machine with Win XP
John
support wrote:And what about #5 ?
JohnRichards wrote:If I look at all these faults and it is not a cable fault or box fault it can only be 2 other possibilities.
John
niesten wrote:Here exactly the same
Sweetlight 512 box, always worked fine. A few weeks ago updated to windows 10 and the laptop doesn't recognize the box (0 universes found) and the box shows the standalone led.
DMX bargraphs are showing signal, only 1 light connected (2 diff dmx cables checked, 3 different usb cables, still nothing). Light works with another DMX controller so light is working...
Looks like there is some driver issue for the sweetlight box in windows 10
Anyone who has Sweetlight box working on windows 10 ?!?
Users browsing this forum: No registered users and 24 guests
