selecting interfaces for each universe
start all applications from here
Postby kjensen77 » 22 January 2016, 19:31
How can you select which interface is associated with which universe?
I am using an x-factor & a SAA. i need the ssa to be universe 1 but when i plug in the x-factor that one gets assigned to universe 1 & ssa to universe 2.
Reason is my external dmx board does not work via dmx in on x-factor but does work via dmx in on ssa unit.
kjensen77
Re: selecting interfaces for each universe
Postby support » 22 January 2016, 22:20
The order of the universes is given by the operating system.
If you reverse the usb connexions, the order should be reversed.
Postby support » 10 August 2016, 15:54
FYI, V8.1.15 has a software patch for universes.
viewtopic.php?f=2&t=4528
Return to ControlBoard
