We think we understand you now.
Please let us some time to check that.
So if you save some scenes with this option, and later you uncheck this option and you re-save them, then the scenes will finally not work as expected
Finally - it's a bug, isn't it?
Go to fixture setting window
Double click in the address field on one of the 2 moving Heads (MH) and select for example 3D PAN reverse and store it.
Now double click on the other MH
You'll see that PAN reverse is also selected.
No, the option "3DView reverse pan/tilt" is the same only for duplicated fixtures.
Users browsing this forum: No registered users and 48 guests
