Macros and Multi-Step Scenes/Generator Movements
Postby Pink LD » 06 February 2015, 19:56
Support,
When I change from one Macro to the next but have the same multi-step scene or Generator movement still selected the software throws the movement into chaos to get back to the first step of the multi-step scene/generator movement, as though I have pressed the live button again. I understand that as far as the software is concerned it obviously views it as though I hit the button again.
But realistically if I go from Macro to Macro with the same multi-step scene/generator movement selected in both Macros, the software should just continue the multi-step scene/generator movement right where it was, not send it back to the first step.
Thanks.
Pink LD
Re: Macros and Multi-Step Scenes/Generator Movements
Postby Pink LD » 09 February 2015, 13:14
Any ideas about this? I am getting way too complex trying to work around this problem. Would it help if I created a simple example for you?
Pink LD
Postby support » 10 February 2015, 08:36
Understood, but not discussed in meeting yet.
Postby Pink LD » 10 February 2015, 12:03
Ok. I just figured I was missing something simple.
Pink LD
Postby djhitmansa » 10 September 2018, 18:05
Any workarounds on this? I have the same question and haven't been able to find any other discussions on this.
Thanks!
djhitmansa
Postby Pink LD » 13 September 2018, 15:16
No, not that I know of. My workaround is rather complex.
Pink LD
Postby support » 13 September 2018, 15:21
We will shortly check if we can quickly improve that, or if this will be a long job.
We will come back to you asap.
Return to Live - Buttons
