fade up lights without looping [fixed]
Postby apfoll » 20 November 2014, 18:05
How can I fade lights up from off to full at a time interval of my choice (like 5 secs).
If I use the steps in the editor tab, it cycles back to black and then repeats. Is there a "stop/run" step command or what am I missing/not the correct approach?
apfoll
Re: fade up lights
Postby Lighter007 » 20 November 2014, 21:02
As far as I know there are three ways to do this:
1. Create a new scene with only one step. Set your dimmer/red/green etc channels where you want them to fade to. Set "Fade state" to "fade" (little symbol under each channel). Adjust the time and save your scene.
Now add the light scene to your live screen. When you click on it your dimmer will fade up.
2. Add the scene to your live screen as you did it but right-click on it and select scene settings. Here you can set the loop on 1.
3. May be the easiest: Create a scene with one step. Set your channels to where you want to have them. Now save and add this scene to your live screen. And now
right-click and select "Fade in" and/or "Fade out".
Done ;) maybe hard to understand but easy to do if you know how :D
Lighter007
Greetings from Germany! :)
Lighter007
Re: fade up lights without looping
Postby apfoll » 21 November 2014, 06:21
Thx, I took the more simple route with the fade time in the Live tab. Worked just fine for what I wanted. Thanks again.
apfoll
Return to Live - Buttons
Users browsing this forum: No registered users and 46 guests
