Earl's Screenshots, Version 7
Postby Earl Harvey » 13 June 2014, 13:18
Here's a quick post of my show still in transitional phase...
24 Par 64 LED
4 Q-Spot 260s
2 FX-12 Strobes
1 X-Laser
4 Mini Strips
8 slim 64 pucks
I usually come up with a scene and assign it to a macro... macro 2 I use for strobes and hazer control
I use a Novation Launchpad Mini and Midi Designer on an iPad routed thru MIDI-OX on a PC win 7/64 pro to merge the midi...
I'll try to edit this post as I go along feel free to add any comments or suggestions...
Previously I used an Obey 70 so hence the setup
Earl Harvey
Re: Earl's Screenshots, 7 Alpha 2
Postby support » 13 June 2014, 13:45
This is the first impressive V7 screenshots we see.
Thank you for sharing !
Postby Earl Harvey » 13 June 2014, 17:26
Thanks !
Earl Harvey
Postby Lighter007 » 14 June 2014, 07:51
Whats this thing in your pictures in your 2nd Post? Is it a MIDI Controller? Looks really nice ;)
Greetings from Germany! :)
Lighter007
Postby Earl Harvey » 14 June 2014, 10:13
It an app for the iPad called Midi Designer, you can create your own controllers
http://mididesigner.com/
Earl Harvey
Postby support » 14 June 2014, 14:33
Can you please tell us what OS are you using to run the software ?
(it looks like Windows 98 or 2000)
Postby Earl Harvey » 14 June 2014, 15:12
Im using Windows 7/64 bit Pro
Earl Harvey
Postby support » 15 June 2014, 15:18
Ok noted.
(without skin)
Postby Earl Harvey » 16 June 2014, 10:28
Thanks again for all the help during the past 2 years... Show Xpress has become my favorite trick to pull out of my hat...
It would be interesting to attach a "Strobe Generator" similar to the FX-12 to one of the Master faders so it could be applied to selected fixtures...
I would also like to suggest an optional Master Speed Slider, it would free up the Midi Trigger to use for Toggle/Momentary Midi Triggering...
Thanks to everyone who has posted their screenshots they really help when your just starting to learn Show Express :D
Earl Harvey
Postby Earl Harvey » 29 January 2015, 13:07
7.1.44
Earl Harvey
Return to Screenshots from users
