Not working wth two different computers
live control with Virtual DJ
Postby tjjano33 » 15 August 2022, 23:56
So I have Show Xpress installed on a different PC as my Virtual DJ, I also have show Xpress installed on the same pc as my Virtual DJ. I have both PC's connected to the same network, but my Show Xpress that is installed on a different PC does not read the beats of VDJ. I have Bonjour installed and the Virtual DJ button enabled. When I play music with Show Xpress that is installed on the same PC, everything works fine and it is set-up exactly how my other Show Xpress is set up. Is there something that I'm missing with my other PC?
Any help would be appreciated!
tjjano33
Re: Not working wth two different computers
Postby support » 16 August 2022, 08:27
We see two possibilities:
1. wrong IP address in software parameters
2. Ethernet port blocked by a firewall
Postby tjjano33 » 16 August 2022, 10:46
So I have the two Laptops connected on the same network via wi-fi. Do they need to be connected via LAN cable?
tjjano33
Postby support » 16 August 2022, 11:34
No.
It should work also via wifi.
Postby ineedabeatdj » 01 October 2022, 03:40
Virtual DJ and Showxpress
To make VDJ work on the same laptop (new way)
In Showxpress
File - Preferences - Network
Virtual DJ - Enable ✅ - Port 7350
In VDJ open options - type in os2l - then check ✅ Yes
Play a track in virtual DJand see if the bars are moving in the Beat window of Showxpress. VDJ should appear in the window. Press pause to see if the bar stops. If it does you are set up correctly.
To make work on separate laptops
On each laptop go to...
Right click Internet and go to Open Network & Internet Settings - Change adapter options - click Internet Protocol Version 4 - click Properties - Use the following IP Address
On the Showxpress Computer put
IP Address 192.168.1.2
Subnet Mask 255.255.255.0
Rest Blank
On the Virtual DJ Computer put
IP Address 192.168.1.3
Rest Blank
Make sure the Ethernet adapter is enabled on both laptops.
In Showxpress
External App ✅ Enable Port 7348
Virtual DJ ✅ Port 7350
Plug a Cat5 cable between the 2 laptops
Open Showxpress 1st, once it’s open, open Virtual DJ on the laptop with virtual DJ.
Play a track and see if the bars are moving in the Beat window of Showxpress. VDJ should appear in the window. Press pause to see if the bar stops. If it does you are set up correctly.
Make sure the firewalls are turned off on both computers if it is not working.
ineedabeatdj
Return to Virtual DJ
