Artnet setup
control Artnet fixtures
Artnet setup
Postby rdreiers » 03 March 2021, 09:38
I can't find the the answer so here is the question.
I have a running configuration with a usb interface (former 19" version)
Now i want to add a artnet node and the whole universe 1:1 the same at the artnet node.
Is this possible and how should i do this.
So in the end i want the same signal at the interface as at the node.
Richard
rdreiers
Re: Artnet setup
Postby support » 03 March 2021, 18:10
Please read this to know how to proceed: https://thelightingcontroller.com/viewt ... =81&t=3741
Re: Artnet setup
Postby rdreiers » 04 March 2021, 09:26
Shame, why not easy duplicate the interface out to artnet.
Richard
rdreiers
Re: Artnet setup
Postby Djclub » 05 November 2021, 21:42
Wait what??
If i want to use all 6 universes that the software povides, i cant just connect an cat 5 cabel to the computer and connect thar cable into an enode?? That doesnt work?
I want to use only one cat 5 cabel and get 6 universes out of it and that is only possible through artnet.
If i have understand it correctly you can get 8 universes throught arnet in a single cable. If i connect through analog with car 5 cable i only get max 4 universes in a single cable
So what works?
Djclub
Return to Artnet
Users browsing this forum: No registered users and 40 guests
