Showxpress > Wysiwig - TCP/IP Listen Error Help
Posted: 08 September 2017, 21:36
I've been attempting to route this for hours now.
At the moment, I'm a Microsoft KM-Test loopback driver that I have the IP set to 10.0.0.1, and the subnet to 255.255.0.0
I'm using Luminex Wygalizer for routing the artnet, set to the 10.0.0.1 address. This is outputting to Wysiwyg, which is receiving from the 10.0.0.1 artnet address from Wygalizer.
This is all using the 6454 port, which I'm monitoring using Artnetominator to monitor, which recognizes the Wysiwig arnet receiver as well as Wygalizer.
My problem is solely coming from Showxpress, which when I load it gives me the "Fonction: TCP/IP: Listen error!". I assume this has to do with how the port is being used by the other software, but I'm currently kind of stumped on what to do next.
I'm hooking these up together so I'm able to visualize both the generator and pixel DMX outputs.
Any insight helps. Thanks!
