Add Level is Greyd out [fixed]
Postby whiz_kid97 » 27 December 2013, 05:04
I am new to the board. I imported an ADJ Vizi Spot LED PRO, I need to alter channel 8 "effect_macro" as there is a wash effect values 96 - 127, but the "Add Level", "Insert Level" and "Delete Level" buttons are all greyd out. Some of the other channels are not greyd out, so I am not sure where this is set that would allow me to add Levels to the channel.
Any Help would be Greatly appreciated! Running Show Express v6.333
whiz_kid97
Re: Add Level is Greyd out
Postby marco » 27 December 2013, 05:35
This is because the dmx level is programmed from 1 to 255
First u have to change this.
So make the first one from 1 to 91 then add the wash effect
marco
Postby whiz_kid97 » 27 December 2013, 17:34
marco wrote:This is because the dmx level is programmed from 1 to 255
Thanks Marco, Turns out I just didn't click on one of the Levels.. You have to click one of the levels first, then it will allow you to insert a level. I was able to add the Frost.
Thanks for your help!
whiz_kid97
Return to Setup
Users browsing this forum: No registered users and 3 guests
