May i change a channel in the setup?
Postby jnasser » 10 December 2012, 02:13
I wonder if i could change a channel created in the setup and still have the same scenes created with the editor without touching anything.
I created a Led fixture in the setup, and i made several scenes with the editor, unfortunately the light was not well established and I wonder if you can change the channel and DMX function and get the same result without having to edit the scene.
Thanks.
Julio Nasser
Vermont School
310-621-8372
jnasser
Re: May i change a channel in the setup?
Postby support » 10 December 2012, 07:38
Scenes are binary files, saved from Editor.
They have no link with any channels settings.
So the answer is "yes", the scenes will not be affected by any change in Setup.
PS: you can always do this:
- make a backup of your lightshow
- make any tests you want
- if result is bad, just load back your "backup" lightshow
Return to Setup
