The rule is:
LTP for active channels
FYI: https://thelightingcontroller.com/viewt ... =72&t=3614
I would use it to put all my moving heads in macros to operate together. But then if I wanted two to particularly highlight the drummer or the bridal party or add ambient lighting, then that could take priority. They could be left stationary lighting whatever I want them to regardless of any other button I push, until I take off the button telling them to stop doing that, and then they would fall inline with the rest. It would add up to save so much screen space and programming time.
daan44444 wrote:Hello,
I would like to come back to this topic. I find many more users are starting to create much bigger showfiles with ShowXpress. I have been looking for a button priority feature for ages! I this this could benefit a lot of users.
Programming this doesn't sound too hard as a fellow programmer. Users will get a popup where they can enter and set a priority (e.g. fron 1-255) per live button. When running the scenes showXpress conpares that priority to the other running scenes. This wil also be done when a button is released, to again determine which scenes should be running based on the priorities. Even better would be to be able to set a priority to each channel, but this would be a harder task.
I hope I can persuade you to try and implement this feature. Many people will be able to benefit from this feature.
Users browsing this forum: No registered users and 19 guests
