Page 3 of 4
Re: Lighting Controller Crashes EVERY TIME it's opened!
PostPosted: 28 October 2016, 22:47
by Niffo
Probably fixed in next fix file.
PostPosted: 28 October 2016, 23:22
by benschrade
Great! What is the timeline for the fix file?
PostPosted: 30 October 2016, 10:11
It is on line (V8.1.30).
Please try it and let us know.
PostPosted: 31 October 2016, 17:24
by benschrade
http://download.thelightingcontroller.c ... ew/fix.zip
I downloaded the fix.zip from the link above. It is unable to open, displaying "efk_hardware" not found.
I am currently running El Capitan. What should I do?
PostPosted: 31 October 2016, 17:32
by benschrade
My apologies. I got it to work.
I currently have it up, but am still unable to launch the MIDI cues successfully.
Able to 'learn' the cue and auto fill all the correct information, but doesn't not depress the button, launching the scene, when the cue is given.
PostPosted: 31 October 2016, 17:43
by Niffo
benschrade wrote:Able to 'learn' the cue and auto fill all the correct information, but doesn't not depress the button, launching the scene, when the cue is given.
Please check you are using V8.1.30. In this version, midi is supposed to work exactly like in 8.1.0.
PostPosted: 31 October 2016, 18:13
by benschrade
Currently using 8.1.30. No luck.
PostPosted: 04 November 2016, 00:18
by benschrade
What is the next step?
PostPosted: 05 November 2016, 12:00
by BartKrap
benschrade wrote:What is the next step?
Maybe it's not a problem with the lighting controller, when's the last time you've updated the drivers of your midi devices?
PostPosted: 05 November 2016, 13:24
by benschrade
I haven't, specifically. I will try, but I'm doubtful this will correct anything.
The program is able to "learn" the MIDI commands, meaning that The Lighting Controller is hearing the command and the MIDI is functioning. I've tried with other MIDI devices as well, immediately after drivers were installed.
