Multiple MIDI Faders Crashes ShowXpress [fixed]
Postby Sunrise » 22 September 2021, 22:32
Sending input from 3-4 MIDI faders simultaneously will consistently crash ShowXpress. If I send from 8 faders at once, it will instantly crash. All faders are set up as ControlChange messages. I am using Bome's MIDI Translator as a go-between to manage my MIDI controllers (Livid Base II and Numark Orbit) and allow them to also respond to Traktor Pro 3. ShowXpress will still crash under the load of a single 8-fader wing with Traktor and Bome's closed.
Is there anything I can do to improve stability? Does ShowXpress simply not operate well with simultaneous commands from more than 1 fader?
Sunrise
Re: Multiple MIDI Faders Crashes ShowXpress
Postby support » 23 September 2021, 09:02
Please tell us:
- the Operating System
- the version of our software (in the welcome screen)
And post a link to a ZIP of your lightshow (https://thelightingcontroller.com/viewt ... ?f=3&t=168).
Postby Sunrise » 23 September 2021, 14:31
Operating System: Windows 10 Home, version 21H1 (on current update)
Hardware: Lenovo T470s, Core i5, 20 GB RAM, integrated graphics
MIDI Devices: Numark Orbit, Livid Base II (both devices control the first 4 master faders)
MIDI Software: Bome's MIDI Translator v1.8.3
ShowXpress Version: 9.2.23 - 201127 - 64 Bits
Show File: https://drive.google.com/file/d/1MgVeo6 ... sp=sharing
Sunrise
Postby Niffo » 24 September 2021, 16:55
Could you please also send us the file "param.ini" in the folder "YourHomeDirectory/TheLightingController/" ?
Postby Sunrise » 26 September 2021, 22:45
Here you go
param.ini
(597 Bytes) Downloaded 494 times
Sunrise
Postby Niffo » 27 September 2021, 09:53
We are not able to reproduce a crash moving multiples faders (control change) together from a midi device with the latest software version.
Looking at your lightshow, we think you can try to (one at a time) :
- Update your software with the latest fix file (v9.2.32 at this time)
- Disable midi output from the main preferences (to isolate an infinite loopback problem)
- Disable faders midi output in Live settings (only useful with motorized or lighted physical faders)
- If possible, directly configure your midi device in the software instead of passing by a MIDI Translator (crashes can come from a buggy midi translator as already seen)
In addition, we are going to send you a debug executable of the software wich should display informations at crash time.
Postby support » 27 September 2021, 11:19
Link sent via PM.
Postby Sunrise » 03 October 2022, 21:57
Sorry for the long layoff, but I'm finally getting back to solving this problem.
Here's the error message provided by the debugging console when the crash in question happens.
[image]
Sunrise
Postby Sunrise » 03 October 2022, 23:26
I have, but none of the updates over the past year have had any impact
[image]
Error took longer than usual to generate and came back with a new message
[image]
Error took longer than usual to generate and came back with an identical message to the previous fix
[image]
Sunrise
Postby Sunrise » 03 October 2022, 23:54
Sooo, onto your last fix suggestion:
It's not possible until you either provide us more master faders or support multiple MIDI inputs to a single fader
That said, I started tinkering with Bome's to see if I could eliminate the issue by eliminating code.
1) Disabled the fader input commands coming from the Livid Base II (typically not the cause of the problem) - still crashed, but new error!
MIDI Fader Error - disabled LIVID input to fader.png (8.99 KiB) Viewed 4882 times
2) Disabled the fader output commands passing ShowXpress feedback to both the Livid Base II and Numark Orbit - back to the old error!
[image]
Sunrise
Return to Midi
