Is there anyway to merge 3 generator files in to one ?
Postby fabio1605 » 08 December 2015, 10:46
Hi
I just want to confirm this but on the generator is there anyway to have fixtures doing different paths? as an example
I know you can use the SHift function to kind of delay them a bit, but i need the fixtures to follow different paths altogether.
i have 3 different fixtures, and if they all follow the same generator path they are not very good.
I assume you can only have one path on a generator(i.e you cant have a 3 fixtures following a different path)
If this is the case - is there anyway to merge 3 generator files in to one so that the 3 fixtures work together?
my light show is on this post if you want to look at what i mean
viewtopic.php?f=69&t=4108
fabio1605
Re: Generator Help
Postby support » 08 December 2015, 15:56
In a Generator project, each channel can have effectively only one curve.
We use the "Macro" in Live, to trigger several scene buttons together.
Please note that, in V8, it is possible to set "pallets" points in a curve in Generator. This means the channels can finally execute different curves.
Re: Is there anyway to merge 3 generator files in to one ?
Postby fabio1605 » 09 December 2015, 15:54
Hi
So best way would be to create the 3 different generators - and use a macro to trigger them all at the same time?
I can't get my head around paletts and generator? is there any sort of guide or tutorial - i am using V8 Alpha
fabio1605
Postby support » 09 December 2015, 18:18
Live in V8 is able to play native Generator projects ; so a Macro can trigger several Generator projects.
Sorry but there is no V8 manual for now.
We will first publish some videos here: viewtopic.php?f=80&t=4113
Postby fabio1605 » 09 December 2015, 23:37
How do you do this?
Add 3 gen buttons and then just update the mac as you would with scenes?
fabio1605
Postby support » 10 December 2015, 07:28
Yes.
Return to General software
