Thank you for the feedback.
Good news !
DeeStage wrote:I would be very nice if we can type in a number for the offset of each fixture.
At this time its nearly unpossible to set the pan offset of 8 fixtures to the same value.
moving 8 faders to the same spot is really difficult
DeeStage wrote:Thank you very much for this feature.
+1 for the ability to type in a number of offset for each fixture
+/-100 % would not be the best way to set an offset for my moving lights because it would not be accurate enough.
Is it possible to increase or decrease the PAN/TILT channels by an absolute ammount of DMX Value ?
For instance:
Create a steps scene with PAN at 128 so that all movers will loock straight to front
Open global offset menu and add or decrease the DMX output by
fixture 1: Pan -5 / Pan fine +165
fixture2: Pan +3 /Pan fine +100
The pan fine channel is really nessecary for me becaus im working with Beam moving heads.
without the fine channels its not possible to create an symmetrical parallel look..
I hope you understand what i mean
support wrote:No, this is a dmx value in 16bits.
