Standalone scenes not uploading to 512 Plus [fixed]
Postby djmontieljr » 02 October 2018, 21:28
In the new V9 Version (with 9.1.2 Fix), only 2 of my 18 buttons are functioning on the remote. I tried clearing the data from the 512 Plus and re-uploading to the hardware and could only get buttons 1 and 6 to work. I checked my scn files in the editor from the Standalone-Scenes folder and they all seem to be working fine within the software but not on the hardware standalone.
Not sure if this is a glitch with the new update or i'm not doing something correctly. I Had to revert back to V8 to get the job done to get paid but took a big chunk of time I did not have.
Anyone else?
djmontieljr
Re: Standalone scenes not uploading to 512 Plus
Postby HalsoLjud » 03 December 2018, 18:21
I have same problem, i try to use my SweetLight Rack in standalone mode, last weekend. Only two buttons works on my hardware.
I used software V9.1.9 And i didn't have a older version so i can test if there is a problem with this version.
HalsoLjud
Postby support » 04 December 2018, 09:50
Please try with V8.
V8 is available here: https://thelightingcontroller.com/viewt ... =85&t=4553.
Please note that you will have to revert back the usb driver for V8.
In case of it works with V8, please send us the easiest possible scene/lightshow which illustrates this problem.
If we can reproduce this problem, we should be able to fix it quickly.
Postby pwmoore5588 » 15 January 2019, 00:38
I just purchased the 512 plus with remote and same issue with only button #1 and button #6 working. Running V9.1.9 on Mac high Sierra. Any suggestions as i plan on running in standalone mode only at events.
pwmoore5588
Postby support » 15 January 2019, 09:15
There is effectively a problem in V9.1.9 with that.
It is fixed in V9.1.11 (https://thelightingcontroller.com/viewt ... f=2&t=5922).
Please install the fix (https://thelightingcontroller.com/viewt ... =85&t=3438).
Return to StandAlone
